it says no updates available, and starts cf
it should look like this right (if installed in default location)
C:\Program Files\Flux Media\Centrafuse\UpdateDownloads
with centrafuse.exe and update.xml?
it dont work!
If you do not have internet in your car this is how you can install the update without an internet connection...
First go to the installation folder for Centrafuse and create or make sure there is a sub directory called "UpdateDownloads". If it's not there, create it...
Then download the following file:
http://www.fluxmedia.net/downloads/CF_Update_RC.3.1.zip
Then copy this file into the "UpdateDownloads" directory. Make sure Centrafuse is closed and then run "CFUpdateInstaller.exe".
david
it dont work!
I did this and well now my key wont work...... Updated via internet on my main comp and the key works... weird bug.. annoying.. now i gata reinstall..
Do not unzip the file! Just copy the ZIP file in the folder exactly from the download...
The updater unzips the file and does everything for you... The only file types that should be in UpdateDownloads are ZIP files...
I fixed the online updater as well and will try to work some way to update the updater from the updater
Might have to reinstall with RC3.2/RC4 to get it working, but it was the first trial run of the updater... It was stupid Date Time parse error too...
daivd
you should add in the option of loading this zip onto a thumbdrive so that when its plugged in, centrafuse checks for the file, and if present, it installs the update.
that would be nice
btw, ya it didnt fix my problem of losing all the tracks in the manager, whenever i start the car,its 0 and ill load something up and itll say queue 12 or so
I did exactly what is says above ......... it restartred CF
Then came up with an error........ and now it doesn't work !
Just as well I tried it on the Main PC, rather than the Car first !!
Any ideas ..............
View the 260 Galloping Horses: [images]
what did it do? something more descriptive than it didn't work... Did it create an error.log file? Can you run centrafuse.exe in the installation folder? does centrafuse.exe even exist?
after all that you can always just unzip and copy the centrafuse.exe to the installation folder manually...
david
Yeah i had the same problem...i did exactly as described...
windows says " centrafuse.exe has encountered a problem and needs to close. "
It wont run at all just comes up with the error everytime.
Brent
Same problem here, with my home pc
