Results 1 to 5 of 5
Thread: problem with phone
    Registered User
    Feb 2006
    Berlin, Germany
    problem with phone
    I had phoco befor using cf and its working fine. but with cf I got my phone not to work.
    In the phone wizard I get no pairing. pairing with the bt-stack without cf works fine.
    where is my fault?
    Registered User
    Feb 2006
    Berlin, Germany
    noone here who can help?
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    Quote Originally Posted by chevyunger View Post
    I suppose you don't have the right driver (which has to be 3.x and newer). Pairing does not work with older versions.
    Once the phone is paired there's no need to pair again in the Wizard. If this happens though, your driver install went wrong.
    Skinning to go... VisualDesigner2!
    Registered User
    Feb 2006
    Berlin, Germany
    Quote Originally Posted by zorro View Post
    thanks zorro, I have tested another bt-stick with bluesoleil software and it works.
    Now I have the problem with my headset. In rr i can mark the field in the config and all calls (in and out) were routed over the headset. how can I solve the problem with cf?
    Matthias
    using rr with licensend phoco
    Mar 2004
    Munich, Germany
    Matthias
    There's no difference between the version in CF and the standalone version but the headset is not supported on anything else then Broadcom.
  1. cordless phone problem
    By jstrain in forum Off Topic
    Last Post: 06-24-2003, 11:09 AM
