Results 11 to 20 of 24
Thread: Using RC4 but not detecting USB GPS signal
  1. #11
    Jan 2004
    Use Xport3, and CF will find your gps receiver
  2. #12
    May 2006
    Seattleish, WA
    Quote Originally Posted by clemen View Post
    I don't think that's the issue... JonDubya covered that angle above.
    :: Mark
  3. #13
    Aug 2006
    Yeah i don't think using a port replicator will work, but in any case I'll try Xport3 just to please the masses. I'll get back with my findings. In the mean time, can anybody else advise why this may be happening? Anybody experience a similar problem?
    PS. All good midiwall - text isn't the best medium to describe a problem like this.
  4. #14
    Oct 2006
    St. Louis, MO
    Check the nav settings in CF...make sure the baud rate is correct.
  5. #15
    Aug 2006
    Yep the settings are COM3 and Baud Rate 4800 which is what all the other GPS programs detect (including the TomTom PPC Emulator).
  6. #16
    Aug 2006
    hey all, just to let you know that I tried Xport3 without any different results. Still getting 0 satellites. Any more suggestions?
  7. #17
    Oct 2006
    St. Louis, MO
    With Xport3, does it show the data being passed at the bottom?
  8. #18
    Aug 2006
    Yup it does. It also shows the same data passing through when I use my GPS Utility tool that comes with the Holux unit.
  9. #19
    Aug 2006
    still needing help. Veetid? I saw another post by "vipervin". He's using RC4 Trial and he's got 8 satellites locked. Why can't I get even 1 locked? this is annoying me.
  10. #20
    Feb 2006
    Having the same problem here, i use a Rikaline USB GPS device.
    I've also tried Xport.. no luck so far.
  1. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 11:49 AM
  2. garmin mapsource and usb gps mouse
    By thecrow in forum GPS
    Last Post: 09-26-2006, 02:24 PM
  3. Replies: 1
    Last Post: 08-17-2006, 08:11 PM
  4. Replies: 42
    Last Post: 04-24-2006, 01:27 PM
  5. Window Tint's effect on GPS signal
    By MoFo in forum GPS
    Last Post: 07-19-2004, 05:08 PM
