Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Using RC4 but not detecting USB GPS signal
    Aug 2006
    Hi,
    I've got everything setup fine but when I try to use the Navigator it doesn't detect any of the satellites at all from my Holux USB GPS receiver. I've got the receiver set on COM3 and I can see that it has satellites tracked on the GPS Utility for my receiver, but it doesn't show anything in the Centrafuse Navigator. Is there a way to get this working? Can't seem to find any info on this.
    Thanks!
    Low Bitrate DaKyy's Avatar
    Apr 2005
    Finland
    To be clear, you've set the COM3 to CF settings also?
    edit: Settings -> Navigation -> Port
    Aug 2006
    Yes I have. I've set the baud rate to 4800 which also matches the settings on the GPS Utility. Incidentally, TomTom running on the PPC Emulator tracks fine, it's just CF that doesn't seem to pick up any signal.
    Sep 2005
    Pomona, CA
    Are you talking about Destinator built into CF?
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
    Oct 2006
    St. Louis, MO
    You can't have 2 apps viewing the same com port. You'll have to close the GPS Utility before CF can read from com 3. You can get around this by using a com replicator, I reccomend xcopy3 (search for it here).
    Aug 2006
    Yup it's the built in Destinator on the current CF. I don't have 2 apps open at a time, I'm only stating that to assure that the GPS is functional for other apps but the GPS on CF is not.
    Sep 2005
    Pomona, CA
    Well, the Destinator in CF isn't really supported fully at this moment...
    I use iGuidance, but I think I need to upgrade to get the nice skin working right that some one made for CF - still with version 2.something.
    Carputer Progress:
    Teardown PC [100%]
    May 2006
    Seattleish, WA
    Quote Originally Posted by ahew View Post
    ...I can see that it has satellites tracked on the GPS Utility for my receiver, but it doesn't show anything in the Centrafuse Navigator. Is there a way to get this working?
    Like fatejd said, this is kinda' the state of being right now.
    CF is shipping with a very small set of maps for beta testing - basically a small part of NYC and Germany (I think). David (Mr. CF) doesn't have permission from the Destinator folks to ship all the maps during the beta cycle. They _will_ ship with the full product once CF is released. (date unknown)
    The semi good news is that if you went out and bought Destinator v6 _now_, then those maps would magically work in CF. But, you'd be in a spot that you may have to pay for the maps twice once CF ships - David's trying to figure out that license issue along with everything else he has going on.
    So... bottom line, if you have the locked display showing up in Destinator, that's probably all you're gonna see for a while.
    :: Mark
    Aug 2006
    I don't have the v6 maps (for Australia) but I have the PN maps for Australia which I have managed to bring up (see street names etc). The only thing is that it can't see any satellites (doesn't lock a position and says "Satellites 0" ) which I didn't think was a map issue as the map is just an image with coordinates isn't it? Or am I incorrect to assume that?
    May 2006
    Seattleish, WA
    Whoops... my bad. I misread your previous point, and I even quoted it. I didn't see the what you were finding a lock in:
    My bad, my apologies.
    Yes, I think you should at least be seeing sats locking up in Destinator.
    :: Mark
  1. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 11:49 AM
  2. garmin mapsource and usb gps mouse
    By thecrow in forum GPS
    Last Post: 09-26-2006, 02:24 PM
  3. Replies: 1
    Last Post: 08-17-2006, 08:11 PM
  4. Replies: 42
    Last Post: 04-24-2006, 01:27 PM
  5. Window Tint's effect on GPS signal
    By MoFo in forum GPS
    Last Post: 07-19-2004, 05:08 PM
