I think David has said before that the license manager he uses will detect BIOS date changes. If it sees it happen it'll lock itself down and not allow the parent application to run.
I think the answer is to uninstall from control panel, manually delete the CF directory after the uninstall, then re-install. You'll want to search the forums here to be sure.
LinkBack URL
About LinkBacks
