Important Notes
- uninstall any previous versions of Centrafuse before installing the latest release, not necessary when using updater
- when listening to Radio or XM, voice recognition will not properly work unless you have a USB or Bluetooth microphone, this is due to buffering/recording
New Features
- Added support for DRM protected WMA files and the ability to download licenses
- turn by turn view in navigation uses paging instead of moving a single item
- phone dialogs have been resized to fit in an 800x480 resolution
- added icons to the left side of the navigation map for easy access to functions, a compass, etc...
- added hotkey for add to favorites
- added support for HQCT radio, alpha/beta release version of the radio module
- if "PASWORD" is passed as param2 to CF_systemdisplayDialog when calling CF_Dialogs.OSK or CF_Dialogs.NumberPad the field text is hidden
- weather plugin last updated says today/yesterday instead of date when applicable
- added ability to display Navigation, Web, OBDII, TV, CAM, and External Applications on any monitor, resolutions need to be the same as the primary
- navigation turn by turn list removes turns as you pass them so the top turn is always your next
- added the ability to allow multiple instances of the application to be loaded for server/client environments
Bugs Fixed
- CF_TextItems.CurrenTrackNumber SDK misspelling corrected
- regular microphones will now work with voice recognition
- fixed radio preset saving, you hold for 2 seconds to save
- radio now properly saves the preset names you assign
- you can navigate to a city or postcode without selecting a street
- fixed error some received when saving audio/video settings on initial setup
- saving radio presets automatically pops up keyboard to name the preset after holding them down for two seconds
- next track event should fire for all files including variable bitrate files
- arrow keys properly work in navigation menu
- navigation search properly works with spaces and search speed increased
- current zip and current destination information properly return from getGPSInfo function in SDK
- navigation will load in the background the first time getGPSInfo is called from the SDK if it is not already loaded
- navigation auto day/night skin switch properly works
- navigation day/night mode is not changed when you modify settings or exit the application it is saved
- running as system shell works
- when you exit or disable run as shell explorer reloads when you exit the application
- navigation gives notification of upcoming turns
- fixed default install location in the config.xml for the radiator radio module
- date and time dialogs and outputs properly display based on localization including settings screens
- navigation, web, cam, and external applications stay in fullscreen/non-fullscreen mode when changing skins
- random, connect, and mute buttons properly stay highlighted when switching from sections that cover them
- date and time properly display in phone section based on localization
- left/right arrow keys should properly work in phone section
- when you exit DVD, TV, etc.. the music, radio, or sat radio will not start playing unless it was before
- phone signal strength displayed more accurately
- when switching from cdrom playback back to hard drive playback the cd audio is properly paused
- shift, alt, "..." buttons properly work when used with keyboard and enter key
- mixer section properly works with keyboard control using tab, up, down, left, right
- fixed keyboard control issue with enter key and dialogsinput channel level used by radio and satellite radio is not set to 50, but
- determined based on what you leave it at in the mixer
- input channel used by radio and satellite radio is properly selected and its output channel is properly muted, fixing the double audio problem
- rewind and fastforward buttons properly work in satellite radio mode
- navigation speed is properly displayed
- all values read from configuration files are properly HTML decoded
david
