Hi David, My name is Yossi and i'm from Israel. I'm
testing your
software for the last 3 weeks and I'm doing it because you are the first one that supporting Destinator SDK 5.
We are working here as team for translate this software to Hebrew and i think it will be ready 3 weeks from now. Until that the GPSKeyboard is ready for using it at Israel because all data maps are written in Hebrew so the GPS keyboard should be the same.
I have two problems that I didn't see any questions from others:
I have an
onboard video card with VGA out for the front touch screen and SVHS out for the rear screen. I'm runnig the system on Multiple Monitors as clone mode with full screen
video to the rear screen only. When I start a movie from regular player I can see it full screen on the rear display and I can working with other application in the same time on the main screen but when I'm playing video from CF/media I have to click full screen for it because if I didn't click on the small display I'm seeing the same format as small CF display but full screen.
Bottom line when I'm playing it from CF and didn't change it to full screen, the video on rear screen squeezed by the CF format and the only way to fix it is to double click on small media video for full screen and now I can't change it to other app in the same time.
The second question is some time my
OBD-II (ELM323) disconnected and I need to click for new connection. Did you have any idea what should be the root case?
Hebrew GPSKeyboard photo:
http://www.jeeptrip.com/page.aspx?di...=4&item=740082
