Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 45
Thread: New Release RC4.1
  1. #11
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by kbreeden View Post
    David,
    Support for Winamp DSP plugins is no longer shown on the future features list. You had said on a post a month or two ago that you were actually pretty far along on this. I sure hope its absence from the list was just an oversight.
    not sure how that got removed, I added it back...
    david
  2. #12
    Quote Originally Posted by ShawJohn View Post
    Do we need any codecs installed cause certain albums of mine stammer and make the system very unresponsive... Or is that a DRM problem?
    you should not need any audio codecs and for video I just install FFDShow, AC3Filter, and a good mpeg2 codec such as WinDVD5...
    david
  3. #13
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by veetid View Post
    david
    Good to know. Thanks!
  4. #14
    May 2006
    Seattleish, WA
    Working on that... Also the reason for no live update is the DRM playback, it required multiple steps that needed a new install...
    The next release will include a windows service that monitors music folders, so it will most likely require an install as well...
    ARGH
    Can you AT LEAST make it so that we can keep the previous config files and custom plugins? It's getting to be a real PITA to make a copy of the CF directory, use uninstall, delete the real CF directory, install CF, configure CF, drag the old plugins into the new CF, relearn CF about the plugins, reconfigure the buttons...
    ARGH
    :: Mark
  5. #15
    Quote Originally Posted by midiwall View Post
    ARGH
    ARGH
    there were multiple additions to the config files in the main application and in the plugins, so be careful dragging over those...
    you do have to run through setup again, it's pretty quick and easy... then drag over a couple of plugin folders...
    I agree, but there was a lot that had to be done for the DRM, as well as the next version will have have an option to install a windows service to monitor the music folders for auto updating... after that I see updates via the updater finally being possible...
    david
  6. #16
    May 2006
    Seattleish, WA
    (insert ****y sigh here) if only you had tagged the config files with a version number so that CF could detect an old version, and IMPORT those values into a new format.
    On a desktop machine it's "quick and easy" - with a 7" monitor in a car with a keyboard balanced on my lap and no mouse it takes me about an hour.
    ??? So, installing a service requires deleting/reinstalling/reconfiguring/reloading the whole 40+meg of app?
    I never had that issue with my own installers.
    This is the 6th "release candidate" and the 8th beta I've been a part of. I'm all for long beta cycles, but this part of the process is getting a little old.
    ARGH
    :: Mark
  7. #17
    Apr 2005
    Queens, New York
    David,
    Will this be the final Release candidate?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  8. #18
    May 2006
    Seattleish, WA
    Quote Originally Posted by Cheekz185 View Post
    David,
    I would hope that he will pass out something for verification before actually releasing it. I would guess that there are at least two more "release candidates" before RTM.
    :: Mark
  9. #19
    Sep 2005
    Pomona, CA
    Sounds about right to me - there will always be bugs and limiting them the best will take a couple more releases...
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
  10. #20
    Feb 2004
    As always, a hearty LOL @ anyone complaining that David isn't doing enough to make this process friendly enough for us.
  1. Centrafuse RC4.1 Release Notes
    By veetid in forum Centrafuse
    Last Post: 10-19-2006, 04:32 PM
  2. iGMod Beta 1 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 12-28-2005, 11:17 PM
  3. [SKIN]FPs "Bright Life" (input needed to complete)
    By yunusyu in forum FrodoPlayer
    Last Post: 06-25-2005, 03:59 PM
  4. RELEASE - FreeDrive 0.60
    By CdRsKuLL in forum FreeDrive
    Last Post: 06-10-2005, 05:45 PM
  5. SpeakEasy Voice Recognition - Release 0.9.1
    By ruairi in forum Software & Software Development
    Last Post: 06-03-2005, 06:19 PM
