Results 1 to 8 of 8
Thread: David:AC 97' Sound Card Problem
    Variable Bitrate bishooman's Avatar
    Jan 2006
    Kuwait
    Dear David
    i have this problem since early releases and never been fixed.
    Pre slider in CF ---> controls Wave slider in Volume
    Front Slider in CF ---> controls Master in Volume
    Rear Slider in CF ----> not functiong at all
    i think it should work like this
    Volume Control in CF ---> controls Master slider in Volume
    Front Slider in CF ---> controls Front in Volume
    Rear Slider in CF ----> controls Front in Volume
    i ma using AC 97' Sound Card with leatest drivrs
    Regards,
    We Exist because there is no patch for human Stupidity !!
    We need you ALL Here !!
    Nov 2006
    I have exactly the same problem. I'm using onboard Realtek ALC861 HD-Audio
    Jan 2006
    Kuwait
    Quote Originally Posted by darmok911 View Post
    i also have this sound card built in another motherboard and i have the same problem.
    it maybe RealTek drivers not supported in CF !!
    VENDOR - Centrafuse veetid's Avatar
    I will look into this... It works fine with my AC 97 with the drviers from viaarena.com and with the onboard on my Dell laptop, not sure of the chipset off hand...
    david
    Sep 2005
    I have the same problem on my M1K [AC97].......... I have tried the latest drivers but that didn't change anything......
    Jan 2006
    Kuwait
    who else have same problem ??
    Variable Bitrate mercury7's Avatar
    Jul 2005
    Dallas
    I have the same problem - using Maya EX5 as an external sound card.
    2002 Grand Am progress :
    [••••••••••••••••………] - 80%
    ...complete setup, but still need to make the install cleaner
    Sep 2005
    I have found a way around it....... Not the best option but it works....
    Keep the Windows based Volume control panel open, and hace Centrafuse open. You can then adjus the volume on the rear output channel from the windows based control. Centrafuse will reset the rear channel volume as soon as you adjust the main volume from Centrafuse. So this leads me to say that it has something to do within the main volume control that is resetting the rear channel volume when you change it. Just my 2c.......
  1. Replies: 1
    Last Post: 12-21-2005, 05:29 PM
  2. sound card choice?
    By Mike12086 in forum General Hardware Discussion
    Last Post: 01-24-2005, 06:09 PM
  3. How to hook it all up/How many watts?/What sound card to buy?
    By Seabass in forum General Hardware Discussion
    Last Post: 03-22-2004, 11:28 PM
  4. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 10:01 AM
  5. adding another sound card??
    By moahdib in forum General Hardware Discussion
    Last Post: 04-25-2002, 07:57 AM
