Important Notes
- uninstall any previous versions of Centrafuse before installing the latest release, not necessary when using updater
- when listening to Radio or XM, voice recognition will not properly work unless you have a USB or Bluetooth microphone, this is due to buffering/recording
- if having problems with GPS receiver in SiRF mode, try switching to NMEA mode
New Features
- added auto music scanning for all music paths, if files are copied to any set music paths the library will be automatically updated, only while the application is running
- added new event to the SDK for CF_Event_applicationLoaded which fires when the application has finished loading, should wait until this event to call some system functions
- added the ability to search through all surrounding POI's using the keyboard, supports partial matches so you don't have to enter full names
- focus is given back to the list views in "My Library" after adding, removing, paging, moving forward, moving back, switching library/playlist mode
- added hotkey for go to previous section
- added check for "Album Artist" tag
- if no actions are assigned to all the buttons for a main page section it is skipped when using main page arrows, example no if actions on page 3 the buttons rotate through pages 1 and 2 only
- "My Music", "My Pictures", and "My Videos" are automatically added to your music, video, picture paths by default
- application switches to navigation automatically when you approach a turn if in a route
- navigation shows turn by turn list automatically as you approach a turn
- you can click individual pictures in the media player and view them
- single click on picture viewer rotates through pictures, double click exits
- pictures are displayed in the proper aspect ratio
- embedded file album art, if available, is loaded first before folder.jpg, album.jpg, etc...
Bugs Fixed
- fixed memory leak
- error in navigation intersection routing fixed, appeared after multiple failed routing attempts
- address routing list views such as city, street, postal codes, house numbers, etc... are all properly sorted
- missing postal codes issue fixed
- POI list properly comes back when selecting a POI with a sub category
- street names are properly listed in navigation, sort, and search
- turn by turn list always show next turn at the top of the list and it updates as you approach destination
- removed unusable navigation buttons from the left side of the map
- CF_getGPSInfo properly returns navigation data even if called from a plugin before navigation is loaded
- CF_GPSInfo.SPEED returns the correct value in mph or kmh depending on settings
- CF_GPSInfo.ALTITUDE returns the correct value in feet or meters depending on settings
- click sounds work on all dialogs and video slider buttons
- fixed list view in phone section missing last item when running in different resolutions
- fixed recursive loop in importer
- navigation auto day/night switching works even if change happens before navigation is loaded
- weather plugin updates data as often as allowed when visible or not visible, when an internet connection is available
- fixed CFUpdater so future updates can be updated without a re-install
- full screen visual shows the proper information depending on which section you are in media, radio, or satellite radio
- weather plugin no longers displays no connection setup when it trys to connect to update weather data
- removed navigation map context menu, it was unusable in the car
- turn-by-turn list is automatically hidden when you reach your destination
- fixed bug with loading picture playlist on initial startup
- pictures can no longer get added to music/video playlists, which caused displayed problems
- all labels are properly updated after the skin is changed, mode, title, position, etc...
- fixed bug with auto changing skin while watching fullscreen video, it now stays fullscreen
- fixed bug with generic album art not showing up when mixed with songs with album art
- fixed bug with rear/sub mixer controls
david
