Results 1 to 2 of 2
Thread: DVD Aspect Ratio is wrong. . .ffdshow didn't work
    Variable Bitrate miwise's Avatar
    Sep 2006
    Hi,
    I have a laptop that will only output 800x600 (no widescreen resolutions) and my 16:9 lcd supports 800x600. The problem is that at 800x600, all the movies are squished vertically. first I tried to set centrafuse to display at 800x480 and then stretch everything back to full screen. This didn't work for the dvd video, it worked for the main program, though. I then tried to download ffdshow b/c I saw in other threads that it may correct the issue. It doesn't light up the mpeg 2 check box so that I can select it to decode dvds. I saw where ffdshow would resize the picture (several ways to do this it seems with this program) but I can't make it decode dvds. Where am I messing up? Is it even possible to correct my aspect ratio problems?
    Celeron 2.53 Ghz Processor
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
    mp3car.com XM Direct USB interface box
    1999 Mustang GT Convertible Supercharged
    Sep 2006
    BTW, I may have found a solution on the board in another area. Here's the link: Tutorial: Forcing Custom Resolution in Windows
    I'm going to try it after I get my carnetix installed in the car so I can run at 720x400 (native resolution for my monitor)
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
  1. slim slot dvd rom with wrong adapter, questions
    By mattress in forum General Hardware Discussion
    Last Post: 10-24-2004, 09:51 PM
  2. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
  3. looking to order a slim dvd rom, will this work?
    By DSM97RS in forum General Hardware Discussion
    Last Post: 04-28-2004, 10:06 PM
  4. DVD player work in vertical?
    By alia176 in forum Off Topic
    Last Post: 01-29-2004, 05:10 PM
  5. will this adapter work for the imac slot load dvd?
    By Deuce Bigs in forum General Hardware Discussion
    Last Post: 05-21-2003, 05:22 PM
