Results 1 to 3 of 3
Thread: Centrafuse unresponsive after hibernate/standby
    Jul 2006
    After coming back from hibernate or standby, CF gives me tons of problems
    1) the system is terribly slow, with even the mouse cursor refreshing only every 2 seconds
    2) the audio is messed up, just sounds like digital noise or something (using audigy ZS notebook)
    3) touchscreen doesnt work
    4) GPS doesnt pick up the GPS mouse
    anyone have similar issues? also how do i get windows to not ask me to login as system administrator (Even though there is no password, i still have to click the user)
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by hari-bhari View Post
    It could be one of your device drivers causing the issue... I use RC4.1 with hibernation in my car daily and haven't rebooted in weeks...
    There was a memory leak that might have caused some issues for people, but probably unrelated to hibernation issues...
    You need to add a password to Administrator, then go to run on start menu and type "control userpasswords2". This will popup a dialog, at the top you will see a check box that says require logon, uncheck this and hit ok...
    Then it will ask for a username and password, enter Administrator and the new password you made and you will never be prompted for a password or login again...
    Make sure to also go into power settings and under advanced uncheck for it to prompt for password on resume from standby...
    david
    Low Bitrate 2muchwires's Avatar
    Apr 2006
    Puerto Rico
    Same for me
    Same For Us David, jmoreno@streetconsoles
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Centrafuse New release & mappoint 2006
    By josgab in forum Centrafuse
    Last Post: 09-06-2006, 11:00 AM
  3. New Release, Centrafuse RC1 (1.7)
    Last Post: 08-02-2006, 01:14 PM
  4. Centrafuse SDK Information
    By veetid in forum CF SDK
    Last Post: 11-03-2005, 04:18 AM
  5. Centrafuse Launcher (Fixes Map Movement)
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-02-2005, 03:53 PM
