Page 1 of 5 12345 LastLast
Results 1 to 10 of 41
Thread: Feature Request - Auto Volume w/ Speed
    Jul 2006
    I oftentimes find myself having to turn up the volume once im on the highway, so it would be nice if CF had an autovolume feature to adjust based on speed read from the GPS.
    My gf's h3 has an auto-volume button with three settings: low, medium, and high, which basically adjust how agressively the volume gets adjusted (we keep it on low because its the least intrusive)
    I figured this would not be too hard to do if CF had a built in COM port splitter, or if the user just had a program like xport.
    Let me know what you guys think
    Aug 2006
    i think that would be an excellent idea. it should also default back down to your actual selected volume if your speed can't be read (eg. when you lose your satellite connection through a tunnel).
    Oct 2006
    St. Louis, MO
    IDK about others, but I patch my carpc through my head unit, so it stays at max all the time...
    Aug 2006
    this is referring to the auto volume adjustment utilising the software eg. if you go over a certain speed as detected by the GPS the volume will automatically increase or decrease to accomodate for the increase in in-cabin noise. alternatively, when you come to a red light it will decrease so that you're not blaring up the music for everyone in the next district to hear.
    i'm thinking a lot of people use Amplifiers and not HU's for their setup as well, and since Amps don't have the logic in them it would be good to have this driven through the software instead.
    Sep 2005
    Pomona, CA
    I have this built into my stereo, which I use for controlling the volume because I didn't want to get rid of my stereo, plus I have steering wheel controls. This is a great idea - could grab the info off of GPS (once speed is working consistently) or OBD.
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
    Raw Wave justintime's Avatar
    Apr 2005
    Other front ends can do this, as far as I recall. Would be nice if CF did it too, yes...
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Jan 2004
    would be nice
    VENDOR - Centrafuse veetid's Avatar
    The same person who wrote the non-GUI plugin to set the volume to a specific level when he started the application and resumed from hibernation could convert his code to do this in a few minutes...
    There is a getGPSInfo function to get the speed and he already has the code in place for the volume...
    someone ask for the source and this could happen in no time...
    The reason I built the SDK
    david
    Slovenia (EU)
    Heh, I was just going to ask david if he would provide speed info from OBDII in SDK . OK, first I'll try with GPS. Just one question david; should I make a continuous loop in which I check the speed and than adjust it (the loop would end on exit or hibernate or sleep (or it is not necessary?))?
    Quote Originally Posted by stric View Post
    Just use a timer to check speed...
    I will look to add an OBD speed option as well, so your plugin could check both... check GPS, if it comes back as 0 after a second switch over and try to get it from OBD II
    david
  1. Request: Winamp volume
    By froop in forum Road Runner
    Last Post: 06-07-2006, 03:04 AM
  2. Automated volume based on vehicle speed.
    By The Grinch in forum FrodoPlayer
    Last Post: 03-04-2005, 12:55 AM
  3. volume button speed
    By Bobby Digital in forum FrodoPlayer
    Last Post: 11-18-2004, 01:51 PM
  4. Official requests thread.
    By skippy76 in forum V.O.I.C.E.S
    Last Post: 06-03-2004, 03:56 AM
  5. Volume rise to match increase in road speed
    By SAScooby in forum Software & Software Development
    Last Post: 03-11-2004, 10:55 AM
