Results 1 to 5 of 5
Thread: radio loops
    May 2006
    Belgium
    radio loops
    Hi,
    today i connected my radioXtreme to my car pc...
    the connecting all went wel, but when I'm listening to radio, I get this annoying problem: my sound loops (a 2 sec loop), and it won't stop looping...
    also when i push the play/pauze button it keeps on looping.
    I'm still using RC4 (the oldest) in my car.
    is this known issue? is this solved in RC4.3?
    and... when i'm listening to radio, how do I turn it off? I mean, if i want to listen to MP3, ik keeps playing my radio? also solved in RC4.3?
    Greetz
    Dj NRG
    Aug 2006
    i would try installing the new 4.3 release first, then test it out to see if the problem still occurs. it would make it easier for veetid and others to source out the issue if it still exists after that.
    May 2006
    Belgium
    ok, will install new version first thing in the morning...
    thx for u'r reply
    Greetz
    Dj NRG
    VENDOR - Centrafuse veetid's Avatar
    Also make sure the input is muted in your mixer... It is suppose to mute automatically, but you may have un-muted thinking you were suppose too.
    For example if you are using line-in, the recording device needs to be set to line-in, but in the playback section of the mixer line-in HAS to be muted...
    this is because I record from the line-in and playback, hence the pause/play/rewind functionality...
    if you were hearing a loop, this is most likely the cause...
    david
    May 2006
    Belgium
    ok, just installed the new version (RC4.3).
    when i tune to a station (ex 89.00FM) it starts to loop untill i press the play/pauze button. when i tune one step up (set to 50Khz) it again loops unill i press play/pauze again...
    I'll check later today or my line in is muted...
    Greetz
    Dj NRG
  1. HU Quality AM/FM RDS/RBDS Radio with Features
    By rando in forum Hardware Development
    Last Post: 12-04-2008, 01:11 PM
  2. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 04:34 AM
  3. Stock Radio won't kick on?
    By IntellaWorks in forum Car Audio
    Last Post: 11-03-2005, 01:36 PM
  4. Using radio antenna for radio AND tv
    By pyros in forum General Hardware Discussion
    Last Post: 05-19-2004, 02:06 AM
  5. FM radio Question
    By thepogcbr900rr in forum General Hardware Discussion
    Last Post: 05-09-2004, 07:27 PM
