It seems that my location is not being saved when in the setup screen for the weather on the latest build.
Steps:
1. Go into Settings->weather->location
2. Enter various combinations (city, state, zip, all, just 1, etc...)
3. Hit enter (Get a quick 'loading' box), then save.
4. Location text field is still blank. And when I access the weather module it says "No weather location found..."
Any chance this is stored in some text file (i.e. xml)? Just as workaround, I would like to set this value manually.
I'm actually hoping this is user error vs. a bug...
When you say "search", I'm not sure what you mean. I'll assume that after you enter (for example) a zip code, it uses your internet connection to get the appropriate details.
In my case the location field always ends up being blank.
I'll chaulk this up to me screwing up my install. (I didn't completely uninstall 4.2 before installing 4.3) After (finally) reading the release notes, I uninstalled 4.3, then uninstalled 4.2. I probably hosed something up that way. User error, but hopefully there may be some useful info on your end.
BTW, excellent product. I'm very impressed with the quality/functionality.
