Results 1 to 5 of 5
Thread: Help testing Flux Downloader
    VENDOR - Centrafuse veetid's Avatar
    Thumbs up Help testing Flux Downloader
    I have added an option to the download page. There is now a check box next to the license agreement for "Use Flux Downloader"
    This will install a small ActiveX control that is a transfer manager. It basically allows for the download to be paused, if the internet connection is lost and later restored you can start the download where you left off, resume downloads, good progress indicator, and can minimize to the system tray while downloading....
    I built this for later when people are downloading large files from the server, for example the Centrafuse download with all of Europe will be around 1.2 GB...
    Anyway, if some people will just go re-download RC4.4, don't have to install or anything, and let me know how it works...
    It does not work for FireFox since it's not needed, FireFox has a download manager. It has been tested in IE7 as well and should work fine...
    david
    Mar 2006
    Seems to work fine.
    I paused a few times and it resumed with no problems after a short pause.
    Two things I noticed, it lets you run multiple sessions - you can have two downloads going at the same time to different save locations. And if you pause - change the save to location - resume, it's starts from 0% again. But these aren't anything to worry about.
    J
    Low Bitrate Flappy's Avatar
    Jun 2004
    Netherlands
    Works perfectly here... Also paused several times, without any problems.
    AsRock AM2 dual VGA
    AMD Sempron 3000+
    512MB DDR
    3,5" 80GB harddrive
    Liliput 7"
    TFT 15"
    M2-ATX
    0% [OOOOOOOO-] 100%
    My install
    Newbie MrWhite's Avatar
    Sep 2005
    Sauerland/Germany
    Works great!
    paused many times and even after an half hour it still works.
    Greets.
    Ctrl+Alt+Del
    Registered User
    Nov 2006
    Works Great!
  1. Replies: 33
    Last Post: 05-07-2008, 10:24 PM
  2. Simulating GPS data for testing
    By god_of_cpu in forum StreetDeck F.A.Q.
    Last Post: 08-08-2006, 02:16 PM
  3. FLUX trademark?
    By DiNASTY in forum Centrafuse
    Last Post: 08-02-2006, 09:42 PM
  4. Testing with standard AC supply
    By rockthevolvo in forum Power Supplies
    Last Post: 08-18-2004, 06:12 PM
  5. Problem testing VIA EPIA w/standard atx power supply
    By khufumen in forum Power Supplies
    Last Post: 11-15-2003, 03:22 AM
