Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 37
Thread: OBDII connectivity
  1. #11
    Jun 2005
    MD, USA
    yeah, obd worked great in either rc3 or rc4.x, but now i cant get it to work at all. i tried pressing the connect button maybe 3 times then gave up.
    ill search for a error log if i get a chance.
  2. #12
    May 2006
    Seattleish, WA
    Quote Originally Posted by tibby01 View Post
    I think I last saw it work somewhat reliably around Beta 1.6, maybe 1.7.
    :: Mark
  3. #13
    May 2006
    Belgium
    I also use this cable.
    mine connects in CF, but does not show any data, allthough the data leds are flashing...
    I also will look into my error.log file tomorrow..
    Greetz
    Dj NRG
  4. #14
    May 2006
    Seattleish, WA
    Quote Originally Posted by Dj-[NRG] View Post
    Make sure you have the baud rate set right in CF. The OBD2AllInOne defaults to 9600 but can be set internally to 38400. If the baud rate in CF doesn't match the device, then you could get symptoms like you're seeing.
    :: Mark
  5. #15
    May 2006
    Belgium
    i thought i allready played with the baud rate...
    will check again tomorrow...
    didn't have the chance to check my error log file today, hopefully i will get to that tomorrow...
    Greetz
    Dj NRG
  6. #16
    VENDOR - Centrafuse veetid's Avatar
    We will get it figured out... This was one plugin I did not create, another developer did...
    The only two things I didn't write in Centrafuse personally are the OBDII plugin and the Updater, both of which I am going to start working on... They both have create starts, but I put the developer on other tasks so they somewhat got forgotten about, mainly the updater... it should have been fixed multiple version ago...
    I will post up a debug version for people to run and send me files hopefully next week....
    I just found out today I have Pneumonia, so I will be out sick for a few days... I will still be ont he forums, but probably not doing much coding...
    With all the medicine I don't want to break anything
    We will get it fixed, it's got to be something simple because it's working here...
    david
  7. #17
    Oct 2004
    yea i have the obdIIPRO same things as the rest where it decodes all the types lke OBD all in one module. and it jsut wont do anything in centrafuse it will connect at 9600 but thats it dosnt give me any values sometimes it will but a very few and they dont update they stay withthe first value they got.
  8. #18
    VENDOR - Centrafuse
    raygun's Avatar
    Dec 2004
    Atlanta
    Regarding the AccessPort device. While this device does provide a serial interface, we currently only support the ELM chipset and protocol. Any other serial devices that have Serial OBD-II does not mean it will work with CF, only ones with the ELM chips. This device is similar to the VAG-COM tools used with VW/Audi autos. They provide a serial interface to OBD-II, but not using the ELM chipset.
    This said, it IS possible to communicate with these devices, but we do not currently support them. We may add support in the future but we are currently focusing on finishing the app.
    reagan
    Reagan
    Formerly from Centrafuse
  9. #19
    May 2006
    Belgium
    I checked my logs today, and this is what it says:
    object reference not set as an instant of an object
    at centrafuse.obdii.resetchip()
    in CF when i hit the connect button, it connect without any problem (if i set my baud rate to 9600), but just won't show any data (although my elmscan is sending data according to the flashing leds on it...)
    Hope this helps david and raygun
    Greetz
    Dj NRG
  10. #20
    May 2006
    Belgium
    any news on this?
    Greetz
    Dj NRG
  1. OBDII Signal Splitter (for Infiniti G35)
    By Caelric in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-14-2007, 09:32 PM
  2. OBDii on non-US cars
    By ramy_zohair in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2005, 02:30 AM
  3. OBDII, GPRS, and car control
    By CarBaron in forum Hardware Development
    Last Post: 04-04-2005, 10:25 PM
  4. @ Leddy OBDII
    By gyro in forum NeoCar Media Center
    Last Post: 12-08-2004, 07:43 PM
  5. 1994 Saab 900 & OBDII
    By Shark in forum General Hardware Discussion
    Last Post: 11-03-2003, 09:58 AM
