Results 21 to 30 of 37
Thread: OBDII connectivity
  1. #21
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by Dj-[NRG] View Post
    any news on this?
    Greetz
    Dj NRG
    not yet... it's on my list... I will do the same as I did to fix the VFD once I get there...
    david
  2. #22
    Jun 2005
    MD, USA
    you know what?
    it worked today, connected right up fine. i havent made any changes either...
    weird.
  3. #23
    Quote Originally Posted by tibby01 View Post
    you know what?
    weird.
    that's good that the parsing engine worked in Centrafuse... now need to see why it wasn't connecting before...
    was your connector not secured good possibly?
    I still plan to go through and revamp the OBD code and post updates for people to test, but have a few items I have to finish coding first before I get to it...
    david
  4. #24
    Jun 2005
    MD, USA
    im pretty sure all connectors were fine. the only one i can see coming loose is the actual cable to factory obd port, and i unplugged and plugged it back in many times when obd wasnt connecting to try and see if that was the problem.
    but it seems to be working pretty good now, no clue why, but ill take it.
  5. #25
    Oct 2006
    UK
    My Mitsubishi FTO doesn't support the ODBII protocol, which obviously rules out the use of the engine management pages out of the box. Currently I output engine management data in the Mitsubishi MUTII standard, which is logged by a program called EVOSCAN.
    Evoscan is all well and good, but I'd prefer a proper embedded display such as the one in Centrafuse. Does the software in centrafuse connect directly to the ODBII port, or can it be coded to pickup inputs from another source? I ask this so I can use a program such as EvoScan to dump the data to abother file format for Centrafuse to pickup and display. Is this possible? Additonally, is there any thoughts on the introduction of gauges etc for the ODBII pages?
    Quote Originally Posted by Badgerboy View Post
    Anything could possibly be displayed on the OBDII plugin, currently it reads it's source from the choice of inputs of ELM chips, but I guess it could be set to read from a file as well... I will think on it...
    We do plan to add gauges, but after the first version of the application is completed...
    david
  7. #27
    Oct 2006
    UK
    Excellent. If you need any information please let me know.
  8. #28
    May 2006
    Belgium
    I checked my logs today, and this is what it says:
    object reference not set as an instant of an object
    at centrafuse.obdii.resetchip()
    in CF when i hit the connect button, it connect without any problem (if i set my baud rate to 9600), but just won't show any data (although my elmscan is sending data according to the flashing leds on it...)
    Hope this helps david and raygun
    Greetz
    Dj NRG
    any news on this?
    Greetz
    Dj NRG
  9. #29
    I have not gotten to working on OBDII yet... I have all my bugs seperated by section...
    I should hopefully finish up all application bugs by tonight, then I will be working to fix the 10 or so phone related bugs/fixes that I have...
    Then the last section is OBDII... All this should be happening before the end of the weekend, hopefully...
    david
  10. #30
    Lum
    Lum is offline
    Variable Bitrate Lum's Avatar
    Jan 2005
    Liverpool, England
    Out of interest, is there (or will there be) a plugin architecture for adding OBD-II style plugins at all?
    This means that someone else could produce a plugin for SSM (as used by the Cobb Accessport) or Mitsubishi's system, or Nissan's Consult system.
    Most of the manufacturer-specific diagnostics protocols have major advantages over OBD-II, usually that you can transfer data a lot quicker (eg. Using SSM I can poll every sensor on my car once every 0.2 seconds)
    I realise that writing support for all of them is unreasonable, so hopefully others can do it and display on your gauges when you have them ready.
  1. OBDII Signal Splitter (for Infiniti G35)
    By Caelric in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-14-2007, 08:32 PM
  2. OBDii on non-US cars
    By ramy_zohair in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2005, 01:30 AM
  3. OBDII, GPRS, and car control
    By CarBaron in forum Hardware Development
    Last Post: 04-04-2005, 09:25 PM
  4. @ Leddy OBDII
    By gyro in forum NeoCar Media Center
    Last Post: 12-08-2004, 06:43 PM
  5. 1994 Saab 900 & OBDII
    By Shark in forum General Hardware Discussion
    Last Post: 11-03-2003, 08:58 AM
