Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
Thread: OBDII connectivity
  1. #31
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by Lum View Post
    Out of interest, is there (or will there be) a plugin architecture for adding OBD-II style plugins at all?
    This means that someone else could produce a plugin for SSM (as used by the Cobb Accessport) or Mitsubishi's system, or Nissan's Consult system.
    Most of the manufacturer-specific diagnostics protocols have major advantages over OBD-II, usually that you can transfer data a lot quicker (eg. Using SSM I can poll every sensor on my car once every 0.2 seconds)
    I realise that writing support for all of them is unreasonable, so hopefully others can do it and display on your gauges when you have them ready.
    I either will have a quick solution to adding support or make OBDII a plugin that is included in the SDK you get from the FDN so the community can add support and features...
    david
  2. #32
    Dec 2006
    Center of the Universe
    Quote Originally Posted by veetid View Post
    david
    Amen. Thank you.
    (Twinkle Twinkle little star
    How I wish for the native Subaru protocol
    to work in Centrafuse... )
  3. #33
    Lum
    Lum is offline
    Variable Bitrate Lum's Avatar
    Jan 2005
    Liverpool, England
    Well, there is an open-source SSM query tool out there called ECU.exe it's a commandline thing written in VC++ 2001. I think it came from openecu.org
    I'm not a C expert, but hopefully it won't be too hard to get it to work inside Centrafuse's framework.
  4. #34
    Feb 2007
    Pleasanton, CA
    In my case, I am using the wireless BT on my scantool5 unit and i can see it reading and communicating (RX and TX lights on both the bluetooth adapter and the scantool blink), and centrafuse (latest one) shows it connected - but i get no readouts... .any ideas?
  5. #35
    May 2006
    Belgium
    same problem here...
    david will look into it, but I do not think this has his highest priority...
    Greetz
    Dj NRG
  6. #36
    May 2006
    Seattleish, WA
    As an attempt to keep these conversations together, here's a link to CJ's new thread on the topic:
    OBDII in Centrafuse and Scantool.net elmscan tool...
    :: Mark
  7. #37
    Dec 2006
    Well maybe now with Centrafuse finally released for sale...they can upgrade the OBD-2 functions. I would love a programmable shift light as well or rather some sort of bar graph gauge that goes from red (vacuum) to green (boost) depending on boost. It would probably help me in using less gas.
  1. OBDII Signal Splitter (for Infiniti G35)
    By Caelric in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-14-2007, 08:32 PM
  2. OBDii on non-US cars
    By ramy_zohair in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2005, 01:30 AM
  3. OBDII, GPRS, and car control
    By CarBaron in forum Hardware Development
    Last Post: 04-04-2005, 09:25 PM
  4. @ Leddy OBDII
    By gyro in forum NeoCar Media Center
    Last Post: 12-08-2004, 06:43 PM
  5. 1994 Saab 900 & OBDII
    By Shark in forum General Hardware Discussion
    Last Post: 11-03-2003, 08:58 AM
