Results 1 to 8 of 8
Thread: Stuck with expired CF
    Aug 2005
    Plano/College Station, TX
    I had CF running as a shell in my carputer, but I took it out for awhile and haven't used it. now I've booted my carputer up and it goes straight into CF, but the beta license has expired, so CF closes and I'm stuck. How can I disable "run in shell" on CF so I can uninstall the old CF and install a new version to use?
    Apr 2005
    Queens, New York
    try taking the drive out of the carPC and connect it as a secondary drive on your home PC and then work from there.
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Aug 2005
    I will give that a shot. Anyone else have any ideas?
    Raw Wave justintime's Avatar
    Apr 2005
    Yes, search forums, it was recently discussed. You press ctrl-alt-del, then File > New Task > Run and then type Explorer. Take it from there and see if it helps, or search forum for more detailed instructions from David.
    Hope this helps!!
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Apr 2005
    Incidentally, David: Might want to consider disabling the 'launch to CF' feature when the license expires, so that next boot will launch windows. Can you add that in the procedure?
    2002 Honda CR-V
    Jun 2005
    MD, USA
    ^^^tis a goo idea.
    see me...
    Centrafuse Trial just expired...
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by justintime View Post
    yep... good idea...
    david
    Aug 2005
    Thanks guys! I knew there was something I could do with the Task Manager, but I wasn't sure what it was. I ended up sticking the drive in my home PC and just installing the new CF on my home PC, but the idea to launch to windows once the license expires would really help some of us n00bs out!
  1. stuck on 'verifying dmi pool data' booting from a CF card
    By dyne in forum General Hardware Discussion
    Last Post: 08-11-2006, 10:48 AM
  2. CF 1.5: Expired again?!?
    By Willow in forum Centrafuse
    Last Post: 02-28-2006, 08:32 PM
  3. cf 1.4 tryout expired
    By neon_eddy in forum CF Bug Reports
    Last Post: 12-03-2005, 10:41 PM
  4. XP Pro on CF card working!!
    By knubile in forum WinNT Based
    Last Post: 01-03-2005, 07:48 PM
