Results 1 to 10 of 10
Thread: BLINKing screen with CF
    Constant Bitrate GuMiSZu's Avatar
    Nov 2006
    Hungary
    Unhappy BLINKing screen with CF
    Hi!
    I try the new CF, but if i use it, my screen is blinking/flickering.
    In RR and any win APP the system works great.
    any solution?
    about 5sec good, 1/2 sec black... the VGA signal is off ! when the screen is coming back the LCD write out the active input...
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Mine does this after resume, normally stabalises after a few seconds, try using a different res.
    Nov 2006
    Hungary
    Quote Originally Posted by ShawJohn View Post
    It isn't an LCD problem! If i use the CENTRAFUSE the screen is blinking. If I use anything else the LCD works great. It isn't an LCD problem, it is problem with the CF and my PC
    PC : 900MHz P3,256M (EPC)
    any idea?
    FLASH version is 8
    what can Ido? Any IDEA?
    Aug 2004
    On the edge!
    you know best then
    maybe its a problem with how CF handles resizing, and how your lcd locks on to the vga input...
    Variable Bitrate Redian's Avatar
    Apr 2006
    Connecticut, USA
    you could update yer flash player...
    other than that... update yer video card drivers...
    if it still doesnt work, change yer resolution
    2004 Impreza WRX CarPC Install
    I am willing to host any legal downloads that may benefit the CarPC community - PM for info
    "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
    DG4L
    Nov 2006
    Hungary
    thx
    I will try this..
    FLASH/driver...
    Newbie blckwdw's Avatar
    Apr 2006
    Lansing, Michigan
    I have the same problem, it only recently started (this week).
    I have tried several resolutions and no different, but it works fine out side of CF.
    It seems to happen more if I resume from hibernate, but happens none the less. I am using the lilliput 7" on the VIA SP-1300 with the 800x480 drivers and res.
    Any suggestions david?
    Aug 2004
    On the edge!
    AFAIK this is NOT specific to Centrafuse... I can recreate this problem using RR and any flash based skin. And I have had this problem since RR first supported flash skins!
    But it is defo the Lilli which is causing it. Cause if I plug in a full sized monitor it doesn't do it!
    It is something to do with the way the monitor detects what resolution and refresh rate you are using.
    Mine ONLY does it when in 800x480, in 800x600 it NEVER does it
    I have posted a few times about this but until now no one else had experienced it
    Apr 2006
    Lansing, Michigan
    i tried to switch to 800 x 600 and the same thing happened, i have not tried 840 x 480 though, but I will give it a go. Why does this only happen in centrafuse though, my desktop is 800 x 480 and no flicker.
    Aug 2004
    On the edge!
    AFAIK something to do with the screen boundry area. Because CF is basically a full screen borderless window, the lilli sometimes finds it difficult to detect which resolution you are using and therefore syncs to the wrong settings which causes the screen to flash on and off and be shifted also.
    Running a full screen app like notepad normally stops mine flashing though, problem is you can only press the touchscreen when the screen briefly displays correctly, otherwise nothing works
  1. FAQ: Touchscreens explained
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 07-21-2008, 10:10 AM
  2. BLUE SCREEN on my MONITOR!! WHATS THAT MEAN???
    By ironic in forum General Hardware Discussion
    Last Post: 08-05-2006, 02:24 PM
  3. Lilliput touch screen Help..please
    By avn128 in forum LCD/Display
    Last Post: 08-03-2006, 04:20 PM
  4. Motorized Flip-Up Screen Ideas?
    By DryBear in forum Fabrication
    Last Post: 01-16-2006, 01:09 PM
  5. Screen intereference - Subwoofer/bass related
    By Pabs in forum Power Supplies
    Last Post: 10-18-2005, 03:25 AM
