Results 1 to 6 of 6
Thread: Audio muted when I select media menu
    Constant Bitrate jarred's Avatar
    Sep 2000
    Stockton, CA USA
    I'm not sure if this is a bug or not, so I didn't post it in the bugs thread. I have Centrafuse RC4.4 installed on both my CarPC and an HP Laptop. Whenever I select Media via the menu in my CarPC, mute is turned on. This happens whether from the touchscreen, or via my firefly remote.
    However this does not occur with the install on my laptop.
    I've removed Centrafuse from the CarPC, deleted the flux folders from the program files folder, and deleted the Centrafuse registry entries. Re-installed Centrafuse, and still have the issue.
    Please let me know if there is some configuration file I can modify to remove this behavior.
    Thanks in advance,
    Jarred
    Mar 2006
    I have the same issue but never posted because I figured it was my setup (I've slimmed down xp quite a bit and am also running ewf)
    Hopefully there will be a solution.
    VENDOR - Centrafuse veetid's Avatar
    this is an issue with some sound cards... this should be fixed in the next release....
    david
    Mar 2006
    Thanks for the update.
    Sep 2000
    Stockton, CA USA
    Quote Originally Posted by veetid View Post
    david
    What is the ETA for the next release? Will this be another RC, or will it be the final?
    Quote Originally Posted by jarred View Post
    It will be RC4.5
    We plan to hopefully have only two more release candidates...
    There are a lot of fixes old and new in the upcoming version such as all the XM issues worked out and more...
    I will have it out this week, probably towards the middle to end of the week...
    david
  1. Replies: 19
    Last Post: 12-04-2004, 06:37 PM
  2. My upcoming media player: neocar media center
    By netsuo in forum NeoCar Media Center
    Last Post: 10-04-2004, 10:15 AM
  3. Media car audio playlist
    By Walkman2001 in forum MediaCar
    Last Post: 09-24-2004, 06:52 PM
  4. Launch External Audio from Media Car?
    By Griffin_Dodd in forum Software & Software Development
    Last Post: 03-27-2004, 07:05 PM
  5. Adding file syncronisation to Media Engine
    By skippy76 in forum Media Engine
    Last Post: 03-27-2004, 12:01 AM
