Important Notes
  1. uninstall any previous versions of Centrafuse before installing the latest release
  2. when listening to Radio or XM, voice recognition will not properly work unless you have a USB or Bluetooth microphone, this is due to buffering/recording
  3. if having problems with GPS receiver in SiRF mode, try switching to NMEA mode, if having other issues try GPSGate or XPortmode
New Features
  1. added satellite and terrestrial signals to information display when in satellite mode
  2. holding down XM list view header for two seconds will refresh channel list
  3. added option in audio/video settings to enable/disable control of the rear/sub outputs
  4. if running as system shell and your license expires explorer is set back as the shell and the system reboots automatically
  5. when running as shell if you exit the application explorer will load as the system shell
  6. added the ability to output GPS and OBDII information to VFD
  7. added auto start option to OBDII settings, connects to the car when the application starts
  8. added ability to get OBDII information from plugins, use CF_getPluginData("OBDII", "SENSOR1", ""), SENSOR1 through SENSOR16 are available
  9. added hotkeys for answer/hangup phone
  10. added voice commands for load navigation, load phone, toggle full screen, cancel route, zoom in, zoom out, load navigation menu, and load view menu
  11. added NetStumbler file format to the navigation favorites importer, use CSV extension
  12. loading full screen video from media player is single click
  13. loading the video/DVD/TV pull up menu is single click, except when in the DVD menu it's double click
  14. if you click SMS button in phone while at the root menu you can send a message to a number not in your phonebook, it asks for the number
  15. added hotkeys for hibernate, shutdown, restart, standby, and exit
Bugs Fixed
  1. fixed XM data not populating right for stations
  2. fixed XM not saving last channel
  3. fixed channel change error
  4. fixed XM hibernation problem
  5. XM channels change faster
  6. XM works as the startup location
  7. XM favorites work and are saved
  8. fixed XM display information and channel art in fullscreen visualization mode
  9. XM channel list refresh properly works
  10. fixed XM fastforward/rewind functionality
  11. radio and XM skip forward/back buttons work
  12. XM properly mutes the output line when selected, fixes feedback
  13. HD44780 VFD properly clears the text previously written so the characters do not overlap
  14. VFD properly scrolls main title
  15. navigation voice prompts properly mute when disabled
  16. when startup section is not on page one of the main menu, the proper page is set for when you go back to main menu
  17. weather data is cleared when you change locations so the information properly updates
  18. weather checks for update on resume from hibernation and every 30 minutes
  19. USB CD drives should properly be detected
  20. fixed VFD custom text output
  21. date display and adjustments now properly work based on regional settings
  22. weather plugin does not display today/tomorrow when data is old, but the date last updated instead
  23. removed the "..." elippses at the front back to the end
  24. video window in media player is properly sized when you first load the application with a video playlist
  25. adding artist/albums/songs with the "+" in "My Library" and clicking ok in bottom right does not start over the playlist
  26. adding music to the queue in "My Library" with the "+" and then hitting cancel, the items are properly removed from the queue
  27. fixed bug where music was still playing after loading a CD
  28. fixed the HD count number showing incorrect or nothing
  29. fixed music still playing after ejecting a HD playlist
  30. navigation visual notification setting properly works
  31. updated tag reading code to fix "Unknown Artist/Album" issue
  32. when visualization is on a secondary display, the mini visualization in the media player is properly displayed
  33. when changing visualization display settings while visualization is running in fullscreen the visualization properly closes
  34. selecting music/video/picture paths with no folders works in single click mode
  35. previous selection is remembered when going through navigation menu
  36. single click properly works in navigation menu
  37. single click properly works in media manager
david
