Results 1 to 10 of 16
Thread: Solution to 'Square' character on titles!
    Raw Wave justintime's Avatar
    Apr 2005
    OK, at first I thought this was related only to RC5, but then I did some more testing and figured this out... it turns out that all versions of CF (at least all recent ones) have issues if your extended MP3 ID3 tags are populated.
    If you are having issues with square characters populating on your album titles etc in Media Manager, or perhaps even 'commas' in the Genre listing within CF, then the solution is this:
    -Open up the files with a good ID3 tag editor such as The GOdfather, and perform a Full Tag Edit.
    -Then switch to 'More Data', and finally look at the 'Extended Fields'.
    -If you have any info on those fields, delete them all, save, and re-index your CF library.
    YMMV if you are using a different tag editor. Just try to find a way to see the Extended ID3 fields, and delete them...
    David: You should look at supporting these Extended ID3 fields, they are useful!
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    May 2006
    Seattleish, WA
    Justin; what are examples of the extended tags? Is this the stuff to support chapters?
    fwiw, the 2.4 standard is here: http://id3.org/id3v2.4.0-frames
    then there are addendums:
    http://id3.org/id3v2-chapters-1.0
    http://id3.org/id3v2-accessibility-1.0
    :: Mark
    May 2006
    Seattleish, WA
    n/m I just installed The Godfather and see what you're looking at.
    Wow... yeah, those tags have been around for a while, and what's interesting is that Album Artist is in there which David seemingly started supporting in RC4.4. Hmm... Sounds like he's getting confused with the extra tags.
    :: Mark
    Jul 2006
    i too have this square block problem although ive gone through great pains making all my id3 tags uniform and clean. david, will this issue be fixed? for me, the square block is showing only after the album name at the top of the playlist.
    May 2006
    Seattleish, WA
    side note... David's at CES so any responses from him will be a couple of days off yet.
    :: Mark
    Apr 2005
    Quote Originally Posted by hari-bhari View Post
    Did you read my solution to this? Unless you really need them, just delete the extended tags, and the squares will be gone for good.
    2002 Honda CR-V
    VENDOR - Centrafuse veetid's Avatar
    justintime: can you email me a file to support so I can fix this issue?
    It probably happened when I added the Album Artist support...
    It shouldn't be hard to fix...
    david
    Apr 2005
    Quote Originally Posted by veetid View Post
    david
    David,
    I cleaned all my files already
    Just grab any MP3 file, open with The GodFather, and add an Extended tag of your liking...
    2002 Honda CR-V
    Jul 2006
    i dont see an extended tag option. i see 'standard' and 'extra' and ive cleared all the entries under extra, but my album names still have the square block. either im really stupid, or something else is going on. david, if you'd like an mp3 file exhibiting this behavior, PM me with your email address and ill send it right over. thanks
    I would like an mp3 with the commas near the genre and the squares...
    just reference the topic and send it to the standard support email address on the website...
    thanks, I will get it fixed once I have the files...
    david
  1. What would you like to see in a motorized screen solution?
    By rotarypower101 in forum LCD/Display
    Last Post: 08-20-2007, 10:48 PM
  2. a serious solution
    By sohaibma in forum Power Supplies
    Last Post: 04-06-2005, 03:44 PM
  3. Titles?
    By MP3DUB in forum Mp3car Forum Suggestions/Comments
    Last Post: 07-04-2004, 03:24 AM
  4. Choosing a Character display...
    By Kryten in forum LCD/Display
    Last Post: 10-16-2003, 11:43 PM
  5. Replies: 0
    Last Post: 07-24-2003, 03:42 PM
