Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Thread: Is XM Working?
  1. #21
    May 2006
    Seattleish, WA
    Quote Originally Posted by veetid View Post
    strange... I re-hooked up both my XMPCR and XMDirect using a USB to serial adapter and both did not cause any issues...
    I am still trying to reproduce...
    'k.... I dunno much of what else I can do to help.
    If you want to work out a way to get me a debug build I can try running it under DevStudio and see if I can get you a stack trace or a dump.
    Lemme know... I'd be okay with signing the NDA in that scope.
    :: Mark
  2. #22
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by midiwall View Post
    I plan to look into this and get it fixed...
    I'm just working to get this release out with the updater fully working...
    Then I can get back to focusing on the remaining bugs... Notice I added all your bugs you posted to the Known Issues thread...
    david
  3. #23
    May 2006
    Seattleish, WA
    I understand, I'm just looking for ways that I can help more. I figured a debug build may be an option since I can repro this 100% of the time and you haven't seen it happen at all.
    Thanks.
    :: Mark
  4. #24
    Thanks.
    I can work with you and debug version to help sort it out once I get this version released...
    There was a user on the Flux forums that was getting that dialog with his XMPCR, but he stopped getting it when he updated his XMPCR USB to Serial drivers...
    Low level it is opening a handle to the COM port, it must not be getting properly closed on hibernate on your system, therefore causing an error when it trys to reopen it on resume...
    I tried a really slow system as well, 600mhz old P3 and still didn't have the issue, but we will track it down...
    I plan to get this release out, then first fix a couple days worth a quick issues that are known and/or found and do an updater test...
    Then I will work with you on XM...
    david
  5. #25
    Raw Wave
    Jun 2002
    Virginia
    David,
    I haven't used CF in a while because of the XM issue. When 1.1 is ready I'll go ahead and download so you'll have another person taking a look at XM.
  6. #26
    May 2006
    Seattleish, WA
    Hey David... I don't know if the feature of "holding down XM list view header for two seconds" to refresh the channel list is such a good idea.
    The issue is that you clear the favorites when you do this. I think that a destructive action like that should be in a tucked-away spot. Basically, just having it on the plugin configuration screen is good enough.
    It's not something that someone would have to do a lot, and it's kindof annoying if someone activates it by accident - which would be me, while I was putting a post-it reminder on the screen so that I'd be sure to see it.
    :: Mark
  7. #27
    I didn't realize it cleared the favorites, I can have it save these...
    I might remove that, it might be a good idea...
    david
  8. #28
    May 2006
    Seattleish, WA
    Either way (save the fav's or pull the feature from the list box) would be cool. Thanks.
    I take it that the favorites index into the main list by channel number? Other wise if something _did_ change in a refresh, then the favorites wouldn't track.
    :: Mark
  9. #29
    that is correct, they save with the channels...
    I will either remove it or save the channels...
    david
  10. #30
  1. XM Equipment CHEAP! XM Direct $29!!!!
    By hevnsnt in forum General Hardware Discussion
    Last Post: 04-11-2006, 10:18 PM
  2. working with xm direct and macxm
    By lovedamacmini in forum MacCar
    Last Post: 11-02-2005, 03:29 PM
  3. Pre-Release Thread: Frodo XM Service
    By frodobaggins in forum Software & Software Development
    Last Post: 08-04-2005, 05:10 PM
  4. XM Direct digital adapter or XM PC cable with SkyFi2???
    By LATEOTT in forum Hardware Development
    Last Post: 01-19-2005, 03:18 PM
  5. Direct Xm working as a XMPCR!!
    By KMorphosis in forum General Hardware Discussion
    Last Post: 10-07-2004, 11:37 PM
