Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: VFD update for testing
  1. #21
    May 2006
    Seattleish, WA
    I was wrong about there being a difference between 1 and 5 chars to scroll, but there is definitely a difference between 20 & 20+ characters, and w/VFD & w/VFD No Title:
    Code:
    Title Length   W/O VFD   W/VFD   W/VFD, no title
    20 chars         3%       25%         25%
    21 chars         3%       53-71%      28%
    22 chars         3%       53-71%      28%
    23 chars         3%       53-71%      28%
    24 chars         3%       53-71%      28%
    25 chars         3%       53-71%      28%
    30 chars         3%       53-71%      28%
    The 53-71 jumping seems to be in sync with the characters physically moving.
    :: Mark
  2. #22
    VENDOR - Centrafuse veetid's Avatar
    I made a couple more improvements, nothing major... might see some CPU decrease...
    The scrolling title just takes a lot of CPU because you have to repaint every character because they all change, so if it's a 2x20 then you paint potentially 20 characters, ontop of everything else... It was 900ms I switched it to 1000ms because it made no visible difference and made it run a little better...
    check other post
    Unzip all files to the Centrafuse install folder...
    I also added a flag in the vfd.xml file to disable title scrolling, just set it to false... I will add it to the VFD settings in the application in the next release...
    not quite sure why the CPU is used so much sending to the LPT port, I get no CPU usage talking directly to serial ports... I am going through inpout32.dll so I guess direct LPT port access is CPU intensive... It is what LCDSmartie uses...
    same CPU issue with PortIO driver as well...
    It handles fine on all my machines, I have no where near the CPU issue described by midiwall
    david
  3. #23
    Quote Originally Posted by midiwall View Post
    Code:
    20 chars         3%       25%         25%
    The numbers are right in ratio, but wrong in value based on my computers... but computers are different... sure you got a good processor
    my slowest machine is a 600mhz P3 with 256 megs of RAM...
    With a 30 char title scrolling I get a max of 44% CPU, when not scrolling I get 10% CPU...
    This is even lower on my M10000, and a bit higher on my M6000...
    I am playing MP3 files with no other sections of Centrafuse loaded but Media...
    maybe your VFD chip takes more CPU to talk to, I have no idea...
    on my 1.73 GHZ PentiumM I barely see any difference or issue with scrolling 4 titles on a 4x20, doesn't phase it at all...
    maybe LPT settings in the Bios? I have no idea...
    It's working though and working for all other users that have tested for me...
    I added the ability to disable the scrolling so you can turn it off...
    Maybe your M10000 won't have the issue...
    david
  4. #24
    May 2006
    Seattleish, WA
    With CF.EXE dated 1/23/07 @ 15:24:
    Code:
    20 chars         3%       17%         25%
    21 chars         3%       56-68%      25%
    22 chars         3%       56-68%      25%
    One new bug I noticed:
    - VFD screen display option "POSITION" is "ELAPSED" in the config section
    :: Mark
  5. #25
    Code:
    20 chars         3%       17%         25%
    Do you mean just the display says Elapsed instead of song position? The code is write as to what it outputs though right?
    david
  6. #26
    Code:
    20 chars         3%       17%         25%
    your numbers are really strange... when you remove the title you get an increase from when you have the title but it's not scrolling? That makes no sense and I cannot reproduce that... Are you adding something in it's place? That might make a difference...
    david
  7. #27
    May 2006
    Seattleish, WA
    Quote Originally Posted by veetid View Post
    Sorry, I skipped a column when transposing from a paper worksheet:
    Code:
    20 chars         3%       25%         25%
    I mean...
    • Settings | VFD | Setup | VFD Output: says "Position"
    • Settings | VFD | Setup | VFD Output | Select "VFD Output Data": says "Elapsed"
    The data shown on the LCD is correct in that it's the elapsed time of the track
    fwiw, I just cycled through all of my BIOS settings for the parallel port ("AT", "PS/2", "EPP", "ECP") there's no difference in behavior.
    I'm loading up LCDSmartie and friends now to see how they behave.
    :: Mark
  8. #28
    May 2006
    Seattleish, WA
    LCDSmartie shows VERY low CPU usage.
    My task manager is set on a 1 second refresh and LCDSmartie may show up every third cycle. When it does, it's showing 3-5% cpu usage... The display is scrolling.
    :: Mark
  9. #29
    strange... I will look into it... I can't test LCDSmartie because the test display that was sent to me doesn't even work in LCDSmartie...
    I already mounted my other two back into their HTPC cases, and the 3rd back into my car...
    So I just have the test unit sent to me...
    david
  10. #30
    Constant Bitrate AngryMan's Avatar
    Aug 2005
    Lewiston, Maine
    I dont have any problem with it.
    I havent set it up in my car yet, but on my xp2600+, I have no laggyness on this one, even if thecpu load is high....
    .______
    / '__|__\____ VW CarPC project
    \(o)_____(o)/ Full Spead Ahead!
    Props to my Sponsor, Summit Adventure Systems Mobile Climbing Walls
    www.summitadventuresystems.com
  1. Chuck's Skins lots of pics Update 7-16-07
    By Chuck in forum RR Released Skins
    Last Post: 11-10-2011, 08:22 PM
  2. 95 Lexus SC300 - 0l33l's "Project SC300"
    By 0l33l in forum Worklogs
    Last Post: 01-14-2010, 08:55 AM
  3. VFD Display
    By leesilk in forum LCD/Display
    Last Post: 04-20-2009, 11:32 PM
  4. GPS Update fequency and Dead Reckoning
    By Scouse Monkey in forum GPS
    Last Post: 05-12-2005, 06:46 AM
  5. Serial 4x20 VFD for Sale $75 Shipped
    By johnram in forum Classified Archive
    Last Post: 06-21-2002, 05:26 PM
