Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 41
Thread: VFD update for testing
  1. #31
    Constant Bitrate AngryMan's Avatar
    Aug 2005
    Lewiston, Maine
    uh oh.. looks like the new fix broke my vfd output.
    .______
    / '__|__\____ VW CarPC project
    \(o)_____(o)/ Full Spead Ahead!
    Props to my Sponsor, Summit Adventure Systems Mobile Climbing Walls
    www.summitadventuresystems.com
  2. #32
    Aug 2005
    Lewiston, Maine
    switched back to the last centrafuse.exe and my vfd display is back.
    .______
  3. #33
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by AngryMan View Post
    broke it in what way? It shouldn't have changed any output features just some small CPU tweaks, or attempts...
    still working to see why CPU is so high...
    david
  4. #34
    Aug 2005
    Lewiston, Maine
    Quote Originally Posted by veetid View Post
    david
    broke it as in, when I unzipped the new exe into the proper location and ran it, I had no vfd output. blank screen. (no bars either)
    I went in, and made changes to the settings. clicked VFD OFF, VFD ON, restarted, etc. no output to the lcd.
    so I switched back to the previous LCD and it started working again.
    I dont really suffer from the cpu load so Ill stick to this exe till I get back from my vacation.
    good luck
    .______
  5. #35
    May 2006
    Seattleish, WA
    This happened to me as well.
    Make sure that you unpack the new vfd.html file that's in the ZIP and put it into the SYSTEM folder underneath the CF install directory. CF needs to see the new tag that's in the XML file. If it doesn't, it won't output to the LCD.
    :: Mark
  6. #36
    You might want to check this thread too...
    VFD Fix for CPU
    The CPU problem should be fixed...
    david
  7. #37
    May 2006
    Seattleish, WA
    It's fixed! CPU usage during VFD scrolling is no different than CPU usage with the VFD module disabled.
    Thank you for sticking with this David!
    So... what'd ya' do?
    :: Mark
  8. #38
    Quote Originally Posted by midiwall View Post
    it was reading from the LPT port that was causing the issues... this is how I did delays...
    I replaced with basic Thread sleeping... I guess reading from the port costs CPU, which is surprising...
    it works though, so I'm happy
    david
  9. #39
    May 2006
    Seattleish, WA
    Yeow... Yeah, reading from a port in a loop is pretty costly. The system ends up in a wait looking for data to get latched.
    Port input is usually done on interrupts so that code is only executed when there's something to do.
    MUCH better call to just use Sleep().
    :: Mark
  10. #40
    Yeah, it was based on HD44780 programming spec though... Wait delays after writes should read from the port to check bytes and loop certain microsecond time delays...
    I still do it for the init process, but just during the writing I switched it to simply sleep the microsecond delays and assume the write worked...
    again though, it's working now so I'm happy...
    david
  1. Chuck's Skins lots of pics Update 7-16-07
    By Chuck in forum RR Released Skins
    Last Post: 11-10-2011, 07:22 PM
  2. 95 Lexus SC300 - 0l33l's "Project SC300"
    By 0l33l in forum Worklogs
    Last Post: 01-14-2010, 07:55 AM
  3. VFD Display
    By leesilk in forum LCD/Display
    Last Post: 04-20-2009, 10:32 PM
  4. GPS Update fequency and Dead Reckoning
    By Scouse Monkey in forum GPS
    Last Post: 05-12-2005, 05:46 AM
  5. Serial 4x20 VFD for Sale $75 Shipped
    By johnram in forum Classified Archive
    Last Post: 06-21-2002, 04:26 PM
