Results 1 to 10 of 11
Thread: How to get PC to hibernate
    Jul 2006
    I set laptop to hibernate after one minute on battery power, but it's not working because CF is still playing music and whatnot. Is there any way to get the computer to automatically hibernate once the power is disconnected?
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by hari-bhari View Post
    you a controller to send the power button press to the computer as soon as you turn off your ignition... these are built into most car power supplies...
    other than that, I'm not sure...
    maybe a registry hack in windows to get it lower than a minute...
    david
    Jul 2006
    sorry, i didnt explain correctly. i dont mind if it would shut off after a minute, but the problem is that it doesn't shut off at all. i think the reason is that the windows power settings are for when the computer is idle. so when cf has music playing, even after a minute of inactivity, the computer doesn't hibernate. any ideas?
    you can set when on battery hibernate after X amount of time, shoudn't matter if music playing... in power settings...
    I thought...
    I don't use laptops in the car, so not sure...
    david
    Jul 2006
    yea i tried what ya said, didnt work. hmm...
    Variable Bitrate daclothe's Avatar
    Dec 2004
    how much ram do you have?
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    Windows settings wont work because as you said your laptop isn't idle. What you need to do is set the UPS section in power management if you have it. If you don't have it then you can set the critical battery alarm up to 98% or something like that and set it to hibernate. Once your battery goes down to the level you set it will go into hibernate. If you set it to 100% it should go off very quickly when the power is removed.
    No idea how your going to power it back up again mind you and if you have a remote button then just set that to hibernate when pressed which is all a shut-down controller does. Still I guess the UPS or alarm route is automatic.
    Wouldn't be too difficult to write an app to do this for you either as you can call windows to see if its on battery or mains then just send windows a hibernate command when it goes onto battery.
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
    Jul 2006
    i have a carnetix cnx-p1290. i know it send a pulse on startup, i wasnt sure about shutdown....
    you should be able to get it to send a pulse on shutdown, then set your power button action to hibernate and you are good to go...
    you can even change that setting in Centrafuse on Ignition Setting, which just changes the power button action
    david
    Jul 2006
    gotcha, thanks guys. i guess ill see what the cnx does, and then if not try with the battery level thing. my only concern is that after time, the battery will get worn down and not even hit 100%. any tips on writing a script? i just wrote my first autoit script to enable and disable my TS using devcon. it reduced by resume time from 2 minutes to 25 seconds and kept the pc from hanging. go figure.
  1. Lilliput works on home pc but not car PC!!!!!!!!!!
    By lax4321 in forum LCD/Display
    Last Post: 02-24-2007, 05:24 PM
  2. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 11:28 AM
  3. Making PC Hibernate when power button is pressed
    By XxAndyxX in forum General Hardware Discussion
    Last Post: 08-16-2005, 10:27 AM
  4. Turn the pc on from the boot
    By NiN^_^NiN in forum General Hardware Discussion
    Last Post: 08-05-2005, 11:42 PM
  5. In progress car PC install.
    By Arathranar in forum Fabrication
    Last Post: 10-20-2004, 12:49 AM
