Results 1 to 4 of 4
Thread: Port splitting for navigation
    Jul 2006
    I am using xport to split my incoming GPS (from port 2) into ports 11 and 12. I can use port 11 or 12 for iguidance, which works perfectly fine, but neither port seems to work with destinator (including the original port 2). Obviously, I select 12 in destinator if I choose 11 in iguidance, and vice versa. Destinator just shows zero satellites. Any ideas?
    Jul 2006
    Seems like hte port number has to be <10. Problem solved. But this is still a strange issue. Is this a bug in CF or destinator? I'm guessing the latter.
    May 2006
    Seattleish, WA
    It's come up here many times - it's a Windows issue. Windows has never been able to deal with COM ports numbered above 9.
    fwiw, I think the problem is even still in Vista.
    :: Mark
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by midiwall View Post
    this has been fixed in the upcoming release... The navigation will work with COM ports up to 64...
    it's a matter of how you call CreateFile that most companies/software do not do, or forget...
    it's something along the lines of most users put
    CreateFile("\.\COM1", ...)
    When to make it work for all COM ports you put
    CreateFile("\\\\.\\COM1", ...)
    I had Destinator make the update and I tested it, it appears to be working just fine...
    Seems like companies would know these things by now...
    david
  1. USB port power dies?!
    By pixelflash in forum General Hardware Discussion
    Last Post: 10-22-2007, 10:26 AM
  2. Com port splitting..
    By Kamakazie2 in forum Road Runner
    Last Post: 10-17-2006, 04:47 PM
  3. SDK commands over the serial port ????
    By tolisn in forum Road Runner
    Last Post: 12-14-2005, 01:03 PM
  4. Replies: 4
    Last Post: 07-04-2005, 05:38 AM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
