Results 1 to 10 of 14
Thread: Please eliminate the need for double tapping
    Feb 2007
    double clicking is inherently difficult on a touch screen especially in a moving car.
    I would recommend that for navigation of the library a single touch of an item will select it and a subsequent tap (at any time) will open it. This would be awesome for cruising through the library.
    alternatively, the little white right arrow buttons on the right side of each item listed in the library could be made to open the item. (I dont believe they have a function currently)
    Either way, something needs to be done to make navigation of the library easier in a bumpy car. Automatic double click can be enabled but it makes navigating the library menu more difficult and prevents you from highlighting an album or genre and playing it. Without it you are forced to "double click" with your finger which is super hard even while stationary.
    PLEASE PLEASE PLEASE!!???
    VENDOR - Centrafuse veetid's Avatar
    why not try going to settings and turning on single click mode?
    david
    Newbie Cabe's Avatar
    Dec 2004
    Portsmouth, UK
    Or you can leave it in the double tap mode and use the Left and Right (Back and Forwards) arrows in the top left corner of the library screen (in the default skin at least).
    Feb 2007
    I've used single click mode but found it frustrating. There are times when you just want to select something and play it. I can't remember what it was but I thought there were a few specific things that were impossible to do when in single click mode. I dont have my system up and running right now but I'll report back.
    Feb 2007
    I see now I can use the forward and back buttons to select an item that is highlighted. This is nice and will be helpful for navigating music.
    I still think it would be really cool if the little white arrow button on each list item was hot so it would open the list item if you clicked on the little white arrow but would only select it if you clicked on the list item.
    Dec 2004
    Portsmouth, UK
    that would be a nice feature I agree.
    that icon changes and is just for display, it will be a arrow if a directory, maybe a start if a favorite, video icon for videos, etc...
    let me know your single click issues... there were a couple in the last release, but I fixed most of them...
    let me know what you don't like about it, I was told by most they liked it and it worked good...
    you can still click once and hit play... It basically remembers what you clicked, not what is clicked on the next screen...
    david
    Feb 2007
    I couldn't find any single click "issues" this go around so it's mostly just a convenience issue now. I really dont want to use single click mode. I want the option of selecting/highliting an album and hitting play. I like that feature.
    I just wish I could navigate the library (without single click mode) with single clicks instead of highliting an item and then clicking the forward button.
    I realize that sounds stupid - why not just turn on single click mode? Again, it's having the option of highlighting an item when you want as well as the option of selecting/executing/opening it when you want. It's a dual-purpose button.
    Feb 2007
    I thought of an example - if you're familiar with Windows Media Center you know you can select a genre, album or artist and hit the "play" button. It will play all of whatever you have selected. However, you can also hit the "enter" button on the item to drill down and select sub-items.
    The problem with single click mode in Centrafuse is that you can't select one genre and play it because it immediately opens the genre. I suppose once the genre opens you can hit play and I think it plays everything. It's much slicker the other way though.
    Quote Originally Posted by danwheeler View Post
    then the way you refer to is double click and using the arrow keys... you highlight your Genre, and you could hit play now... if you want to use a single click to drill into that Genre you would hit the forward button, and the back button to move backwards....
    or you use the single click mode which rememebers what you clicked, for example a Genere... so hitting play now plays all the genres on your screen if you have not drilled down any farther...
    see which you like best and go with one, you will get use to one of them I'm sure...
    david
  1. Replies: 22
    Last Post: 05-29-2006, 11:59 AM
  2. Tapping radio harness for LCD 12V, need diode?
    By buurin in forum LCD/Display
    Last Post: 01-11-2006, 03:52 PM
  3. What I did to to eliminate amplifier turn-on pops
    By lfilomeno in forum Car Audio
    Last Post: 04-11-2005, 07:31 AM
  4. Digital Amps eliminate noise?
    By lbk in forum Car Audio
    Last Post: 08-27-2004, 12:47 PM
  5. How to eliminate noise in audio
    By felix99 in forum General Hardware Discussion
    Last Post: 09-20-2002, 11:31 AM
