I've been playing around with volume control and pre/main master volume settings.
It seems like the logarythmic (sp?) volume setting only works when your pre-out is set as the master volume. Is this correct?
If I have logarythmic volume turned ON and my pre-out set as my master volume control I can see that when I use the volume buttons in CF each subsequent volume up click raises the volume slider double what it did before.
If I have logarythmic volume turned ON and DONT have my pre-out set as my master volume control I see that the volume buttons raise the volume in equal increments.
So I THINK what I'm trying to say is logarythmic volume only works when you have the "USE PRE AS MASTER VOLUME" buttons set to "YES"
Also... the EDIT: Logarythmic volume setting should probably be in the audio settings section with all the other audio related buttons.
it's hard to tell if it's working. I do know that visually the slider doesn't represent logarythmic changes in the mixer but I really can't tell the difference between log volume and normal.
what's actually the difference between logaritmic volume and normal volume setting?
Greetz
Dj NRG
well... one is linear and one is logaritmic... google it and there are a ton of explanations...
the problem is a lot of newer sound drivers have implemented logaritmic volume with the linear windows mixer, which is why I made it an option to only cut on if you need it...
basically if you are using Centrafuse and notice that all your volume change is in the lower or upper end only, like you generally only see a couple of bars or all of them, then you should cut on logaritmic volume and it will give you better volume control...
if it works fine, then don't mess with it, your sound driver is already handling it just fine...
david
aah...
will check tomorrow if it's turned on...
if not i will surely turn it on; i have that problem...
Greetz
Dj NRG
