Important Notes
- uninstall any previous versions of Centrafuse before installing the latest release
- when listening to Radio or XM, voice recognition will not properly work unless you have a USB or Bluetooth microphone, this is due to buffering/recording
- if having problems with GPS receiver in SiRF mode, try switching to NMEA mode, if having other issues try GPSGate or XPortmode
- when I refer to adding parameters to the application it is best to add it to your desktop shortcut in this format, make sure parameters go outside the quotes: "C:\Documents and Settings\David\Desktop\Centrafuse\centrafuse.exe" -nowarning -nolimit
New Features
- added support for more languages and keyboard layouts for both the application and visual/voice prompts in navigation, now included supported languages include (English, Danish, French, German, Greek, Italian, Norwegian, Portuguese, Spanish, Swedish, Turkish)
- when in random mode and song selected in library it will start with that song first and not a random song
- when phone is setup you can directly call points of interest from the navigation menu
- added an option to turn on/off whether master volume adjusts rear/sub levels
- made it optional to buffer radio and satellite radio
- when CF_Dialogs.DateTime dialog is called from the SDK a result value with the specified date is returned
- added get next turn to CF_getGPSInfo
- added navigation next turn to VFD output options
- added minimize to available button actions
- added option to use front as your master volume control
- added hotkeys for skip forward/back, it skips 10 seconds in audio mode, 30 seconds in video, chapters in DVD mode, channels in sat radio mode, and presets in radio mode
- added option for SMS text messages be read back using text to speech
- added feature to set click sound volume level in settings, good for when a music/DVD/video playback is loud
- added motion check, based on integrated GPS speed, if the car is moving fullscreen visualizations, fullscreen video, DVD, TV, WEB, and the Navigation menu are disabled (if this is not a law in your country run Centrafuse with a -nolimit parameter to bypass), we hold no liability for changes made by persons to the application within regions where these features are not legal
- added message dialog on initial startup with a standard warning and liability statement (if this is not a law in your country run Centrafuse with a -nowarning parameter to bypass)
Bugs Fixed
- fixed VFD output and CPU usage
- fixed GPS COM ports not working over COM9
- fixed large media files taking a long time to load
- fixed typo in getConfigSetting for Language in the SDK
- if viewing "My Library" and navigation turn approaches, the screen properly switches to show you the turn
- uninstall no longer fully deletes directory, it leaves any playlists, added plugins, skins, etc...
- fixed issue with squares showing up next to albums
- fixed issue with commas showing up next to genres
- CAM remembers start in full screen option when selected in settings
- clicking drop down menu while open properly closes the menu
- importing a CD properly works and does not cover other dialogs
- importing a CD writes to the proper directory
- while importing a CD you can click away form the dialog and leave the tools section and always come back and click import to check the status
- double click properly works in DVD while in a DVD menu
- going to navigation settings from the drop down menu and hitting save does not cause map display issue
- skin, resolution, and language properly update after initial setup
- changing skin or language properly resizes the media player video window
- the taskbar is properly displayed if a license error occurs
- increased the size of the main temperature display in the weather section, it no longer gets cut off
- title/artist/album are all properly updated when switching between media and CD's in the visualization information display box
- fixed localization problem with date/time dialog
- when exiting the system from the exit menu and running as shell, the shell is properly loaded
- if all HD playlists are ejected the queue is properly cleared
- button click sounds work when using DVD
- if settings or configuration files get corrupted they will repair themselves, stops initial setup from starting everytime you run the application
- included plugins now check if the main application language/skin has changed and auto change to the new language/skin if it is available
- weather section no longer hangs for long periods of time when trying to download weather information, data is downloaded in the background now
- navigation will not automatically switch screens while exiting the application, which caused it to lock up
- dial up networking now properly displays messages
- radio and satellite radio should resume playback when muted by navigation when giving directions
- DVD is paused during incoming phone call and resumed when the call is finished
- DVD now remembers your current rear/sub levels as well as your front/master
- search properly works in "My Library" while in single click mode
- fixed video slider not showing up when the lower half of the video screen was clicked
- tools import utility properly works in single click mode
- music does not go to 0 when you enter media section on certain sound cards anymore
- button actions and plugins display in the proper language
- phone is properly reloaded after importing vcards
- phone properly dials the selected number home/cell/fax
- phone SMS and other dialogs properly stay ontop until you click to close them
- phone you can send SMS to highlighted home/cell/fax number but if you are in another section you get a dialog to enter a number to send the SMS
- phone properly starts playing music when phone call has ended
- phone does not overwrite to the error.log file
- phone properly dials a number when it is double clicked
david
