not currently a way to have the application not remember your music... it will always remeber your last playlist, but all your older ones could be not loaded if you deleted the two ".dat" files, they both have the name playlist in them...
there is only three in the directory, so make sure NOT to delete main.dat...
I guess you could try a shutdown command from settings to run a ".bat" file to delete these two files, that might work...
try at your own risk to the stability of the app, or backup before you delete things...
david
LinkBack URL
About LinkBacks
