Where the shell is specified in the registry, add the command-line parameters to the end...
There's a writeup on this in the FAQ Emporium here: How to: Change windows shell
Make certain to pay attention to posts #26 & 27.
-nolimit -nowarning
How do i add these useing regedit as i run as system shell. This is so my work mae can add the new location of our delivery
It's a good idea. Where I live it's $275 and 3 points (out of a total of 12 available) for having a video/dvd playing while in view of the driver while moving.
On a bit of a tangent, I always thought it would be a good idea to have the option to have a small video overlay (if you have a front facing cam) that can sit in the corner of your screen, so that if you do need to look at your carpc (change music, look at the nav screen etc) you have a little window giving you a front facing view.
Yes it's going to be small and give you minimal detail, but it can't hurt to igve the driver a general picture of what is going on when he's not looking at the road...
I installed my carpc into my pet Kangaroo, mate.
ok, where in the reg editor is centrafuse to add this. I don't run as a shell, but still a bit confused i understand that i have to leave the parameter outside of the quotes, but i can't find centrafuse in the registry in the first place.
"Toilets scare the crap of of me..."
If you're not running as a shell, then the entry won't be in the registry.
Find the shortcut that you use to launch CF, then:
- Right click on the icon
- Properties
- Shortcut tab
- Add " -nolimit -nowarning" to the end of the line in the TARGET field. Don't forget the leading space in front of "-nolimit".
- Click OK
You should be all set the next time you run CF.
:: Mark
