Results 1 to 4 of 4
Thread: CF keeps muting my Line-in and Mic
    Mar 2007
    Winnipeg, MB, Canada
    I use my soundcard's Line-in for TV/FM and Mic Input for XM. Whenever I start CF it automatically mutes both of these inputs and I get no sound from TV, FM or XM. If I then go into Windows mixer/volume controls and unmute them they work fine, but then CF will mute them again next time, so I have to keep going into Windows volume control to unmute. I have the correct input lines selected in CF settings. Any ideas? My soundcard is onboard Realtec HD. Thanks.
    VENDOR - Centrafuse veetid's Avatar
    It is suppose to mute the output of the sound, it records from the input... Make sure the Line-In, Mic are selected as the recording device when you click to enter the section...
    Then it plays back through a buffer which allows you to use the mixer, the visuals to work, play/pause/rewind, etc...
    I did add a feature in Centrafuse 1.1 to disable audio buffering which stops it from muting your inputs...
    david
    Mar 2007
    Fort Meade, MD
    where is the control to disable the buffer?
    Quote Originally Posted by drblast33 View Post
    If you are talking about the radio buffer, in radio settings... If you are talking about the XM buffer then XM settings...
    david
