Hey mate dont usually post on these forums but i have found a solution to your problem, and i find it works great. i take it you are using destinator 6 maps, if so then u most probably have the destinator 6 console that comes with these maps, if u aint then u are gonna need to get it to be able to use the speed camara warnings the way i do! anyways if ya have got it then you will need to convert your csv files to dat files, this is what destinator console does, (havent tried anyother converter) once you have converted them you may have to search for the .dat file, it will be named the same as the csv but with a .dat ext. once you have found that rename it 'Auto Alert 1', once you have done that put Auto Alert 1.dat in the favourites folder. Thats the Hardest part done. now go into centrafuse and go to nav, now this bit is easy if i explain it right, if you cannot do it with these instructions then i will re-write them better. anyways. click anywhere on your map, a little drop down menu should appear click on the 'add as favorite' this will bring you too destinators favourits screen just add the favourite for the time being, once you have done that you should notice back and forward arrows at the top of the destinator favourites window, if you go BACK until you cannot anymore you should see a list of your favourites, the should be a closed eye next to Auto Alert 1 clck on that and the eye should open, then click close at the top of the destinator favouritres window, and there you have it Speed Camera Warnings in centrafuse.
When you approach a speed camera then the lady shouts 'FAVOURITES ALERT' in process of changing that at the mo!
also put the image into your favourites folder and use paint to change it to a BMP, it is the perfect size.
Any trouble then just post back onto this forum, and hopes this helps you and a whole lot more Brits
LinkBack URL
About LinkBacks
. It only adds favs as centrafuse does.
