Results 1 to 10 of 10
Thread: centrafuse problems when using minlogon
    Oct 2006
    I just installed centrafuse RC5 and i am having a problem with it. If i am logged in as default user (using minlogon) then when i click on Centrafuse it acts as if it is the first time i have started it and asks me to set it up. The settings are the same as the way i had them before, but it asks me to go through the set up again each time i start centrafuse. Also, once i go through the settings, all the buttons and the menu are blank, and clicking them doesn't do anything
    If i switch back to normal winlogon and log in as the administrator then i don't have either of these problem. I have tried installing centrafuse as the administrator, then using minlogon, and i have also tried installing centrafuse as the default user. It's the same problem either way i do it.
    Any suggestions?
    Thanks,
    Sean
    Jul 2006
    this problem is not solveable at the moment. try with version 1.1 when it comes out
    Mar 2006
    You must be setup with nlite.
    Oct 2006
    yes i do have an nlite OS install. Is this a known problem? i hadn't read anything about it yet. i am suprised to hear that no one is running an nlite OS with minlogon and centrafuse. would it make a difference if i made centrafuse my shell since that is what i was planning on doing?
    thanks,
    sean
    Low Bitrate spudgunblunder's Avatar
    Aug 2005
    I'm using nlted XP Pro Sp2 using the settings in post #28 from here.
    (for speech recognition enable Media\Speech and System\CTF in the .ini file)
    When using minlogon.exe and CF as shell
    merge this reg file:
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
    "Config"=dword:00000007
    Rather than:
    "Config"=dword:00000017
    This prevents the selected shell (CF) trying to restart when you shutdown.
    Regarding your troubles with CF and blank buttons, I had the same thing if I installed without 1st uninstalling the previous version.
    Oct 2006
    spudgunblunder, thanks for the registry info, i will change that value. This is a fresh nlite XP install, and there was no prior installation of centrafuse, so i know that isn't the problem with the buttons. Are you using minlogon?
    hari-bhari, where did you read that this was a known problem? would you mind linking the thread so i can read some more information?
    has anyone else out there gotten minlogon to work with centrafuse in nlite XP?
    thanks,
    sean
    Aug 2005
    Why not try a new install using the nlite settings I linked (whick work for me) or just do a full install?
    Oct 2006
    The nlite settings i used were almost the same as the ones you used. I was using post #28 from that thread as well. I used the newest version of nlite, so a couple of things changed, but not much. Before i started reconfiguring my nlite OS and reinstalling i wanted to get more information to find out if it has anything to do with nlite at all.
    I do appreciate the responses. Anyone else had this problem, or is anyone else using nlite, minlogon, and centrafuse successfully?
    thanks,
    sean
    Jul 2006
    sorry dont know where the post is, but there was a lengthy discussion about this earlier in a thread in the CF section, try running a search. i too have nlite and i couldnt get minlogon to work, so i gave up. i figure if using CF as a shell, and nlite with all unecessary services stopped, it wont make a huge difference. i hardly saw any actually when booting up windows.
    Oct 2006
    Thanks hari-bhari, i will try looking for that thread again.
    Update:
    Success!!
    The information from post #9 on this thread http://forums.fluxmedia.net/showthre...=4237#post4237 solved it for me. Basically you have to set your TEMP and TMP to point to C:\TEMP instead of what they are set to. Now i have nlite working with minlogon and centrafuse.
    Thank you guys for the information.
  1. Problem with minlogon and Centrafuse
    By proximo in forum WinNT Based
    Last Post: 12-01-2006, 08:07 PM
  2. minlogon mod problems
    By enhanced08 in forum WinNT Based
    Last Post: 06-19-2006, 07:13 AM
  3. Sound Quality In Centrafuse
    By thenick100 in forum Centrafuse
    Last Post: 04-24-2006, 02:31 PM
  4. Thank You - CENTRAFUSE!
    By ScarFace in forum Centrafuse
    Last Post: 10-20-2005, 02:49 PM
  5. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 01:55 PM
