Results 1 to 9 of 9
Thread: embedding applications
    Sep 2006
    I have just upgraded to a new harddrive, fresh install of XP, and CF 1.1 I'm not sure if this is a bug or a problem with my xp config but I am unable to get any programs to embed into cf. CFIG, notepad etc load in their own windows with a blank grey box behind in cf. I did a full xp install, ran 2fastxp and disabled some services. I have tried both partial window names and full window names with no success. Any other ideas? I've never had this problem with any other CF version.
    Sep 2006
    Problem has been solved. The Error logs indicated an error with the performance counters, I was then able to find the instructions to fix the problem and posted them below.
    I succeeded to reenable the appropriate performance counter by opening
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\PerfProc\Performance
    in
    the registry and removing an entry named "Disable Performance
    Counters".
    Raw Wave justintime's Avatar
    Apr 2005
    I was going to suggest that exact thing. It is a common thing really.... we should make that a FAQ somewhere!
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    VENDOR - Centrafuse veetid's Avatar
    What setups have this disabled? I thought this was enabled by default... Every Windows XP SP2 install seems to embed fine for me...
    david
    Apr 2005
    I doubt that default WIndows setups have this disabled.
    In my case, it was one of those opular Windows 'optimizer' applications/scripts that turned it off.
    Quote Originally Posted by veetid View Post
    david
    2002 Honda CR-V
    Sep 2006
    I suspect it was the 2fastxp script that turned it off in my case.
    Jul 2006
    is there any option to make an embedded app exit when you go back to the main menu, or close when you go into hibernation? i wanted to embed google earth but i know it hogs a ton of resources, so i didn twant i running in he background while i didnt need it.
    Quote Originally Posted by hari-bhari View Post
    there is a close button in the header for the external application... you can close and exit the application and only load it when you need it...
    david
    Dec 2006
    Quote Originally Posted by justintime View Post
    Which one and how did you turn it back on?
  1. Replies: 21
    Last Post: 08-22-2006, 08:43 AM
  2. LQuickcam Embedding
    By crankshaft in forum Centrafuse
    Last Post: 08-20-2005, 10:37 PM
  3. Default Applications do not work.
    By Meelobee in forum Road Runner
    Last Post: 05-27-2005, 12:04 PM
  4. Problems when embedding applications
    By anohman in forum RR Bug Tracker
    Last Post: 03-07-2005, 03:44 PM
  5. Add Applications - Applications Screen
    By frodobaggins in forum FP FAQ
    Last Post: 12-01-2004, 06:38 PM
