Results 11 to 20 of 23
Thread: OBDII in Centrafuse and Scantool.net elmscan tool...
  1. #11
    Feb 2007
    Pleasanton, CA
    Quote Originally Posted by veetid View Post
    I will look into allowing you to manually disable PID's...
    The thing is I run a query to the car to get supported PID's and do not request a PID that your car says it does not support...
    It was to fix this exact issue reported in earlier versions...
    I will verify it's working and maybe that is the only issue...
    david
    I am going to have to say that the feature you described is not working properly. As I mentioned before, OBDGauge on my PPC tries to seek every possible PID that is programmed into it from the OBD system - and when the car says "NO", the program does not request it again; seems like CF's plugin keeps asking for them over and over and over again which freaks the car's OBD system out.
  2. #12
    Feb 2007
    Pleasanton, CA
    those should just stay at NA if the plugin detected that your car did not support those PID's
    I will look over the code, but instead of making the user manually disable sensors, I generally try to disable them by the first call after connect is build a list of all supported PID's in a hash, this is a call that I thought all cars supported...
    maybe some cars don't support the actual call to get the supported pids... didn't think of that...
    for example in my car it doesn't support multiple items, but they just stay at NA and it never try's to query for them...
    I could have an error in the code as well or some car again might not support the call to get supported PID's... I will look into it...
    it's a good place to start for sure.. I can start by making a debug version that just gets speed and if it works for everyone and connects and updates, then I know it's me asking for an un-supported PID causing problems...
    I have something to start on now, this a good thing!
    david
    Well I can tell you exactly what works for me and what doesnt work for me; also from my experience it seems like the CF plugin tries and contact every PID once, gets an N/A then tries to contact them AGAIN and thats what throws the car off. I can see random readouts, but then it just stops transmitting. If you can perhaps make a debug version with the ability to completely disable a PID - I'd be happy to test it out and let you know the results.
  3. #13
    Feb 2007
    Pleasanton, CA
    bump cuz i really want to get it working ^_^
  4. #14
    May 2006
    Seattleish, WA
    Quote Originally Posted by ComradeJew View Post
    Easy dude, David's a bit busy, he knows this is here...
    If you wanna help him out, load this up and pull a trace on the virtual COM port that's being used for the OBD interface. It should tell you exactly what's going on:
    http://www.serial-port-monitor.com/
    I was planning to do it this weekend, but a whole mess of "life stuff" came up.
    :: Mark
  5. #15
    Feb 2007
    Pleasanton, CA
    Quote Originally Posted by midiwall View Post
    Ahh okay - I'll give it a shot when I have time
  6. #16
    VENDOR - Centrafuse veetid's Avatar
    CeBit almost over, I will start to have time to wrap up these few issues...
    we only have a few major issues... I should have 1.12 update ready and a new installer this time within days...
    This fixes the last few small items found...
    Then since I have a good idea what the problem is I will post debug versions of OBDII and get it fixed...
    then 2 major XM issues and we are good to go...
    the rest can come out in updates post launch...
    david
  7. #17
    May 2006
    Seattleish, WA
    ... just in case you thought I wasn't paying attention.
    "new installer"... so, we get to delete and completely re-install again?
    :: Mark
  8. #18
    read it... It says 1.12 update and installer... Lots of people were upset I didn't put also the complete 1.11 installer as well as the udpate..
    I will be doing both this time...
    yes I will be using the udpater...
    david
  9. #19
    May 2006
    Seattleish, WA
    Well, the text is "I should have 1.12 update ready and a new installer" which looks a lot like two things, a) the 1.12 update, b) a new installer.
    Glad to hear I read it wrong.
    :: Mark
  10. #20
    Feb 2007
    Pleasanton, CA
    Oh hush you let the man do some magic ^_^
    in the meanwhile - i am gonna go fail some midters :death:
