Important Notes
  1. uninstall any previous versions of Centrafuse before installing the latest release, unless using the updater
  2. when listening to Radio or XM, voice recognition will not properly work unless you have a USB or Bluetooth microphone, this is due to buffering/recording
  3. if having problems with GPS receiver in SiRF mode, try switching to NMEA mode, if having other issues try GPSGate or XPortmode
  4. when I refer to adding parameters to the application it is best to add it to your desktop shortcut in this format, make sure parameters go outside the quotes: "C:\Documents and Settings\David\Desktop\Centrafuse\centrafuse.exe" -nowarning -nolimit
New Features
  1. you can use a real keyboard in the navigation address dialog but you must first tab out of the list view
  3. added option to completely disable integrated navigation in settings
Bugs Fixed
  1. fixed phone SMS dialog hanging when text to speech is enabled in phone setup
  2. folders appear at the top of the list when browsing by music folders
  3. "+" and "-" are properly disabled on dialogs in setup
  4. internet phone number dialog uses the OSK instead of the numberpad to allow the typing of necessary characters
  5. improved internet connectivity detection
  6. fixed bug with list view hold and scroll while in single click mode
  7. radio disables if set to none in settings while loaded
  8. rewind, play, and fastforward are properly disabled when radio or XM buffering is turned off
  9. updated Norwegian, Swedish, Turkish, Italian, German, and Danish GPS keyboard files
  10. fixed problem with slower machines not reloading desktop when exiting application, while running in shell mode
  11. removed satellite channel refresh feature from list view header, refresh channel list from satellite settings
  12. updated PhoneControl wizard that works better with the Microsoft Bluetooth stack
  13. application gets focus back when you exit full screen visualizations or videos
  14. visualization resizes properly after you change resolutions
  15. weather plugin updates properly when switching between imperial and metric mode
  16. weather plugin refreshes faster
  17. weather plugin XML node issue has been fixed
david
