USB radios suck by design. They are all bad.
HQCT is the only option right now other than a HU.
Please write down your usb fm radio, you use with centrafuse.
Now, i have radioextreme, but the receiving of this radio is very bad
And i don't have RDS, too ...
I want use another usb radio with a good receiving & RDS.
Has anybody a reference for me?
thanks!
1.9in x 2.9in -- 47mm x 73mm
Thats my experience, tooUSB radios suck by design. They are all bad.
HQCT will work with CF?
In CF i can't find a option to select HQCT as radio.
If i can use HQCT with CF - i'll buy it![]()
actually the SiLabs reference design FM radio works GREAT!
With a`n extern antenna? Im searching for a good USb radio solution too. The price for HQCT is a bit to high
So CF is working good with the silabs radio?
BTW: Is this radio working with CF? Its constructed in the same way like the silabs but maybe it has different drivers who are not working with cf?
Support for HQCT was removed in version 1.10 b/c they didn't think anyone was using it. There is discussion for bringing it back.
ThaTool, you may want to check out this thread in the Fluxmedia forums and you can let David know that you also want HQCT back for the next version of CF.
http://forums.fluxmedia.net/showthread.php?t=1000
Don't bother with the ADS one in the link... I personally tried it after reading a couple reviews. The reception is also horrible with this one. Not sure what these reviewers were listening to.
EDIT: The ADS one is based on the SiLabs stick. The above that I mentioned pertains only to my testing it on my Car PC. Today I tried it inside on my laptop, and it does in fact get very good reception. The input jack for the external antenna appears to be a standard male SMB connection (I can't verify this 100% until I plug an SMB female end into it). With that being said, I am going to attempt to locate (or fabricate) an adapter that will allow me to connect my stock antenna connector to the input of this stick. If I can get my car's antenna hooked up to this, I'll be fully in business. (Except that CF does not support this stick... I plan to make a Radiator plugin for it once I get to that point though).
EDIT AGAIN: The connector is MCX, not SMB.
if they or anyone with the know how would make some drivers for cf i have fixed a raido shark to work with the car just need to test and i'll post pics when i get home from work tonight.
