I have a 600mhz P3 with 256 megs of ram that CF with navigation runs just fine on...
By design .NET will use whatever memory is available, it is the design of the CLR... So the memory footprint of CF will be larger if the memory is available, this to make the application run faster by not always deallocating memory...
not sure why you had issues... With a standard XP install I have seen it work with 256 multiple times... Never tried it with phone loaded, but that is why we recommend 512, but it will run on 256...
try 384 on that system, or try that system with a full XP install without all the tweaks, maybe something is wrong...
david
LinkBack URL
About LinkBacks
