Great news!
Those are some good ideas, I will look into them after I get everything fixed...
I have re-enabled all the sensors now, but added some new functionality to OBDII...
you can now click each sensor and set it to disabled and it will remember after you restart, etc...
this way it will only query the sensors you want it too...
I did overlook the get supported PID code and it looks right, but atleast in the next version if it isn't working a temp fix will be to disable the sensors causing the issue until I fix it...
I will also check on it not getting all the codes...
so I will wrap this up and get onto fixing that XM issue...
also the next release will have a brand new navigation engine, completly different... it includes street names in 3D mode, visible terrain changes in 3D mode, much improved routing engine, support for most all GPS receivers in NMEA or SiRF mode, much better...
one problem though is I might not be able to use the updater to send out the new navigation engine, but it won't change for atleast a year now... It's hot of the press...
It's over 600 new files and folders... I know you will be really upset if I don't get the updater to work and I will see if it works right, but it's so many files and folders...
An upgrade this large might have to warrant a new install, but I'm tracking down all the issues finally...
I will post 1.12, then we will debug XM!
david
LinkBack URL
About LinkBacks
