Results 1 to 5 of 5
Thread: Controlling Rear and Sub With Audigy 2 ZS
    Variable Bitrate Redian's Avatar
    Apr 2006
    Connecticut, USA
    i know how you would set it up for the m1000 onboard sound (and all via chipsets i presume) but how can you have CF take control of the rear and sub control on the audigy 2 ZS?
    it sucks because i have pre/main/front where i want it, then i just have sub and rear at the bottom... doesnt look nice, and makes it hard to just disable speakers
    so... help? please david or anyone else ^^
    edit: the drivers probably dont let you... do they?
    2004 Impreza WRX CarPC Install
    I am willing to host any legal downloads that may benefit the CarPC community - PM for info
    "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
    DG4L
    Mar 2006
    Correct.. it is a driver issue. Just curious, but are you using kx project drivers or just the standard drivers? I know David got a chance to fix the problem with CF and the kx project drivers not working together. I think he did mention when he gets time he will try to fix it, but I don't think it is a top priority (i'm talking about the kx project drivers in specific)
    Apr 2006
    Connecticut, USA
    kx drivers
    yeah i dont use em, although they are better quality and more efficient too, they arent nearly as stable, so i went with the lesser creative...
    and i dont think he fixed the problem, i updated my drivers a couple weeks ago to that after installing the new verison of CF and they still didnt work
    DG4L
    Sep 2006
    You can also use the YouPax Drivers with Audigy 4 Software, it works lika a charme. I switched from kX drivers and is works fine.
    May 2007
    Wichita, KS
    Quote Originally Posted by dudeness View Post
    reviving an old thread here, but i've tried youpax drivers and they dont work worth crap.... what version are you using, and where did you get them from?
