Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 46
Thread: Centrafuse 1.12 Bugs
  1. #11
    May 2006
    Seattleish, WA
    Quote Originally Posted by ComradeJew View Post
    Apparently if you upgrade to 1.12...
    "upgrade"? Yeah, you'll have trouble if you don't uninstall 1.11, then manually delete the whole CF folder, and then install 1.12.
    :: Mark
  2. #12
    Mar 2005
    Pomona, CA
    Yes, I was able to get XM to work. It didn't work right off the bat. I entered the wrong com port, and then corrected that. I had to refresh the channel listings, and go into frodosatradiox to make sure all was okay. Once I did all that, it worked, aside from the few issues I mentioned about the static.
    Another one I remembered. In the main menu for the phone app, I still see funky characters like "Main Menu - yyyyyy - !yyyyyyy " with some squiggly things above each character. I think I have seen this in almost every release.
    Also, is there any way to make an option for volume control speed? I use a powermate, but the few times I do click up and down on the volume control, it moves waaay too slow. I think this needs to be adjustable for user preference.
  3. #13
    Newbie MrWhite's Avatar
    Sep 2005
    Sauerland/Germany
    Hallo all,
    i found the following Bugs:
    1. The navigation voice sometimes stottert at the start of the sentence
    2. If you enable "one click" you cant load the "favorit" playlist. It just load the two words "favorits" and "queue" into the player.
    MrWhite
    Ctrl+Alt+Del
  4. #14
    Feb 2007
    Getting "not currently available" when trying to select MapPoint 2006 as my navigation engine.
  5. #15
    May 2006
    Seattleish, WA
    Quote Originally Posted by danwheeler View Post
    Yeup, we all are... There's a little bit more about this here:
    MappPoint 2006 "not available" error
    :: Mark
  6. #16
    Jul 2005
    Moscow
    RADIO button is'nt work!
    I try to adjust Cantrafuse that radio worked through a radiator. When I press the button of RADIO at me there is a menu but reactions to buttons any are not present. I cannot cause the menu of adjustment of frequency, to thumb through frequencies it is impossible... Centrafuse not start a radiator. Even if the radiator is started, Centrafuse it does not see. But! In version 1.10 all worked!
    and....
    this - http://forums.fluxmedia.net/showthre...=5903#post5903
    Sonata Project [##########] 100%
    Corolla Project [##--------] 20%
  7. #17
    VENDOR - Centrafuse veetid's Avatar
    The radiator plugin has not changed in a long time...
    Is it creating a error.log file?
    david
  8. #18
    Mar 2005
    Pomona, CA
    I am really liking this new version...
    Anyway... it crashed on me once today while I was seeking through a song.
    5/1/2007 4:25:44 PM
    Unable to open COM1
    at centrafuse.SerialStream.Open(String port)
    at centrafuse.satradio.satPowerUp(Int32 channel)
    5/1/2007 4:45:14 PM
    The system cannot find the file specified
    at System.Diagnostics.Process.StartWithShellExecuteEx (ProcessStartInfo startInfo)
    at System.Diagnostics.Process.Start()
    at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
    at CFIG.CFIG.loadCFIG()
    5/1/2007 4:48:14 PM
    5/3/2007 4:25:41 PM
    URI formats are not supported.
    at System.IO.Path.GetFullPathInternal(String path)
    at System.IO.File.Delete(String path)
    at web.favorites.removeBtn_Click(Object sender, MouseEventArgs e)
    5/3/2007 4:25:44 PM
    5/3/2007 4:27:42 PM
    The given path's format is not supported.
    at System.Security.Util.StringExpressionSet.Canonical izePath(String path, Boolean needFullPath)
    at System.Security.Util.StringExpressionSet.AddExpres sions(String[] str, Boolean checkForDuplicates, Boolean needFullPath)
    at System.Security.Permissions.FileIOPermission.AddPa thList(FileIOPermissionAccess access, String[] pathListOrig, Boolean checkForDuplicates, Boolean needFullPath, Boolean copyPathList)
    at System.Security.Permissions.FileIOPermission..ctor (FileIOPermissionAccess access, String[] pathList, Boolean checkForDuplicates, Boolean needFullPath)
    at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync, String msgPath, Boolean bFromProxy)
    at System.IO.FileStream..ctor(String path, FileMode mode)
    at web.favorites.addfavBtn_Click(Object sender, MouseEventArgs e)
  9. #19
    Jul 2005
    Moscow
    Quote Originally Posted by veetid View Post
    david
    Yes, creates, but about a radiator there is not present lines... Here a log created on a house computer (neither the radiator, nor a tuner on it is not present)
    Code:
    04.05.2007 16:39:26
    Date contains a syntactic mistake in expression of inquiry 'EmailDate < #04.04.2007 16:39:25#'.
       at System.Data.OleDb.OleDbCommand.ExecuteCommandTextForSingleResult(tagDBPARAMS dbParams, Object& executeResult)
       at System.Data.OleDb.OleDbCommand.ExecuteCommandText(Object& executeResult)
       at System.Data.OleDb.OleDbCommand.ExecuteCommand(CommandBehavior behavior, Object& executeResult)
       at System.Data.OleDb.OleDbCommand.ExecuteReaderInternal(CommandBehavior behavior, String method)
       at System.Data.OleDb.OleDbCommand.ExecuteNonQuery()
       at Email.Email.getEmails()
    04.05.2007 16:39:32
    Retrieving the COM class factory for component with CLSID {27CE07CA-A416-4811-A25A-02DF14ABE44C} failed due to the following error: 80040154.
       at GPS.GPSForm.AOCeNuTpo99B0sjk61jN0Rqi()
    This all
    It seems to me that Centrafuse at all tries to start a radiator
  10. #20
    Registered User
    Feb 2006
    Berlin, Germany
    bad navi engine
    Sorry david,
    but the new navi engine isnt as good as the last one.
    Today I tried to route. The engine seems to be a little hectic. Standig at a traffic light it recalculates the route 5 times. At the next ligts Im stopping and the arrow moves forward and recalculates again, but I was on the right way.
    I use the berlin demo map and this never happens befor with the old engine.
    Please punch the destinator-boys and get a bugfix.
    Matthias
  1. Centrafuse 1.12 Release Notes
    By veetid in forum Centrafuse
    Last Post: 04-27-2007, 03:31 PM
  2. Centrafuse 1.11 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 04-16-2007, 10:28 AM
  3. Centrafuse 1.1 Bugs
    Last Post: 03-13-2007, 08:11 PM
  4. Centrafuse RC4.3 Bugs
    Last Post: 12-10-2006, 01:48 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 07:51 PM
