Page 5 of 5 FirstFirst 12345
Results 41 to 46 of 46
Thread: Centrafuse 1.12 Bugs
  1. #41
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by midiwall View Post
    Any word on when you're looking to release the fixes? My truck's been really quiet, I'm starting to hate the sound of my wheel bearings.
    Will have the last issue fixed tonight, it took a little bit... I had to rewrite how all the navigation list screens worked to improve speed with loading full streets, cities, postal codes, and fix all the searching...
    I plan to have it ready tomorrow...
    I just received two phone issues I plan to try in fix in the morning, but they shouldn't take that long...
    david
  2. #42
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Quote Originally Posted by Mr. K View Post
    Something's gone wrong with the master volume control - can't get it to do anything. The pre-amp volume keeps getting set to max every time Centrafuse is run.
    Have you got the speed sensitive volume plugin running?
    If not it could be something to do with the 'right click on hold' settings for the touchscreen. If I have right click enabled it stops me holding down buttons such as FF/RW & volume in CF.
  3. #43
    Newbie Mr. K's Avatar
    Aug 2006
    Irthlingborough, UK
    Quote Originally Posted by ShawJohn View Post
    I've not got any plugins installed. I'll have a look at the 'Right Click on Hold' setting because I've never been able to hold buttons down for very long. I've managed to get the master volume to do something by fiddling with the 'Use Pre-Amp as Master' and 'Use Front as Master' settings but its not really idea.
    The PreAmp level being set to max every time Centrafuse closes down is more of a major problem. I've worked round it by turning the level on my amplifier down but it now takes forever to turn the volume up and down.
    I've uninstalled, deleted folder and reinstalled without any luck.
    I'm going to try the volume at startup plugin to see if that helps.
  4. #44
    May 2006
    Seattleish, WA
    I fiddled enough to get XM to work and noticed a couple of things...
    • The first time that the XM module loads, even if you don't have buffering enabled, you need to hit the "PLAY" button in order to hear anything.
    • If you happen to abort a Channel List Refresh (i.e., click anything in the module while a refresh is happening) a number of weird things happen:
      • None of the buttons on the left work (e.g., ALL, MUSIC FAV, etc).
      • You will get sound out of only the FIRST station you select. All other attempts at changing stations result in the top line of the display changing, but the physical station never changes. (This is _similar_ but not the same as the "single-click UI" bug. In that bug the station will eventually change if you click enough.
      • Repeated attempts to change stations will lock the module (and CF). Forcing CF to quit via task manager will leave the audio from XM playing, which makes sense.
      • Any favorites you set won't be saved.
      • The channel list (in it's incomplete form) won't be saved.
    Thanks for the update on the timeline David - GOOD LUCK!
    :: Mark
  5. #45
    Mar 2005
    Pomona, CA
    I just noticed another issue this afternoon.
    Last time I drove the car was 2-3 days ago in the evening. I left CF in the GPS section (I am using the CFIG plugin with IG 3.0.0). When the computer resumed from hibernation this afternoon, IG displayed fine, but the top and bottom visible bars of CF were blacked out. A second later, a black (what would I imagine is loading dialog) box appeared over IG for a few secs. After 10 secs or so, the CF skins returned and all was fine.
    Was this some issue with CF switching skins from day to night?
  6. #46
    May 2006
    Seattleish, WA
    More OBDII issues..
    • Will only stay connected for 30 seconds
    • Won't automatically reconnect after hibernate
    • Likes to report an MIL code of "P0D3B"; looks like it's parsing a carriage return and a semi-colon.
    :: Mark
  1. Centrafuse 1.12 Release Notes
    By veetid in forum Centrafuse
    Last Post: 04-27-2007, 04:31 PM
  2. Centrafuse 1.11 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 04-16-2007, 11:28 AM
  3. Centrafuse 1.1 Bugs
    Last Post: 03-13-2007, 09:11 PM
  4. Centrafuse RC4.3 Bugs
    Last Post: 12-10-2006, 02:48 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
