First off, the weather plugin said there was a newer version already installed and it wouldnt continue instalation?
The playback resume after phone call issue seems to be resolved. Cool! I havent tested recieving/accepting phone calls yet. I'll give that a try tomorrow.
1. The XM static bug I mentioned in 1.12 is still present. Same issue as before. XM does work after resuming from hibernate when in the media section though!
2. Most every time I have tried to seek through a song, it would stick and fast forward all the way through the song. It required me hitting another button for it to stop.
3. I am still able to reproduce the media playlist count issues with cd's with mp3's on them. Once loaded, CF adds a count to the USB media playlist count, but tells me there is no USB device when I go to play them back. Upon clicking CD, it reloads everything and adds another count to the USB playlist. I don't recall how, but I was also able to get the CD count to 1 with no media in the CD drive. Not quite as bad as it was before, but still not perfect.
4. Last thing I noticed tonight... I inserted a CD that had a few scratches on it to test the playlist count issues that I had before, and CF came to a crawl, forcing me to end task it. I am not sure if this was due to the potential bad/lacking data on the disc, or something else.
Other things to note:
With front set as master, the volume up down arrows do not work, and it always shows "Volume Min" Not sure if that's as designed or not... it doesnt seem right. I use a powermate, so its not a super huge concern as I can still adjust the volume with it, but I figured I would note it. All of the volume control options seem somewhat confusuing, esp if using the volume plugin. Any clarification there as to how it should all work together nicely?
Edit 2: After messing with the volume stuff some more late tonight, I did notice that with or without the volume plugin, the pre and wav volume levels would default to level 50 upon restarting the app or hibernating. Is it supposed to do that? It kinda kills the ability to set a max level using the wav output as well as as causing a few other issues. Bug?
LinkBack URL
About LinkBacks
