i had an issue today where cf started loading as if it were the first time run. I had 1.14 up and running on the machine for a couple of days and it was working fine before this last reboot. I made significant changes to the button layout and also changed some settings for the weather (entered zip- which came up fine) and phone plugins (un-enabled and then re-enabled my phone to try to get it to reconnect to the phone) After closeing cf, rebooting and starting cf it kept bringing me into setup. I clicked through the setup by pressing ok to each and did not re-build the library and then the main cf screen came up, but there were no labels or icons on any of the buttons (including the menu dropdown)
here is my error log:
Code:
5/30/2007 6:37:44 PM
Unrecognized database format 'C:\Program Files\Flux Media\Centrafuse\main.dat'.
at System.Data.OleDb.OleDbConnectionInternal..ctor(OleDbConnectionString constr, OleDbConnection connection)
at System.Data.OleDb.OleDbConnectionFactory.CreateConnection(DbConnectionOptions options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningObject)
at System.Data.ProviderBase.DbConnectionFactory.CreateNonPooledConnection(DbConnection owningConnection, DbConnectionPoolGroup poolGroup)
at System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection owningConnection)
at System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory)
at System.Data.OleDb.OleDbConnection.Open()
at centrafuse.id3reader.readThread()
5/30/2007 6:37:46 PM
Object reference not set to an instance of an object.
at centrafuse.main.runLaunchCommands(String section)
5/30/2007 6:38:35 PM
5/30/2007 6:38:37 PM
5/30/2007 6:38:43 PM
5/30/2007 6:39:46 PM
5/30/2007 6:39:48 PM
5/30/2007 6:39:54 PM
5/30/2007 6:40:08 PM
