Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 51
Thread: Centrafuse 1.14 Bugs
  1. #31
    Apr 2005
    Queens, New York
    WOW all i can really say is great work david. I will be honest though. Since I have had RR i have been pretty happy with it. I stopped testing centrafuse a little while back and I found it to be unresponsive on my system. It kept freezing up (this was a while ago). But today I decided i was goign to install Centrafuse again in the carPC. And it is SOOOO much better. Seriously what a drastic improvement. I feel that it runs sooo much better then before. I am stil testing it out and I really am enjoying it.
    But I have some minor issues.
    -When I add iGuidance as an application, it worked fine but for some reason it assigned iguidance to every BLANK button. I had to remove iguidance from the buttons and just leave it on one.
    -Finally I am trying to test destinator with the NY maps. I have a sirfIII GPS receiver and it cant lock on to any SATS. I have the com set correctly. I have tried switching from SIRF to NMEA and also tried changing the BAUD but it still doesnt work. Also, just out of curiosity, in the NY map is it the entire map? Because it cant even find my zip code, my GF zip code nor our STREETS... No big deal cuz I am still using iGuidance....
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  2. #32
    VENDOR - Centrafuse veetid's Avatar
    the sample map of New York is not the full map...
    There was a GPS issue in 1.14 that has been fixed...
    I am looking into your issue with the blank buttons, was this with a standard external application? After you added it from Settings?
    david
  3. #33
    Apr 2005
    Queens, New York
    Quote Originally Posted by veetid View Post
    david
    It happened when i added iguidance 3.0. And it basically put iguidance in all of the buttons that were empty. I haven't tried adding annother application.
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  4. #34
    Quote Originally Posted by Cheekz185 View Post
    I cannot reproduce this just adding an external application... could you give me steps to reproduce this issue with adding to all blank buttons?
    david
  5. #35
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Its a corrupt XML file I reckon
    Mine did this first time I added an External app.
    Just open the buttons.xml file and the errors will most likely be obvious
    HTH
  6. #36
    Nov 2004
    Question
    Quote Originally Posted by t_bear View Post
    GPS not recieving any data?...
    This latest release is the only one I've had trouble with getting gps data. I'm using a haicom reciever, and the test prog that comes with the gps shows that there's gps data coming on com3. I've checked and doublechecked my port and baud settings. But still the destinator doesn't get any data (yes I did close the test prog before starting centrafuse.. so there's no other prog using the com port). I'm not using any gps port splitter sw.
    I haven't activated centrafuse (haven't had a internet connection on my carputer yet).. is this required before destinator starts using the gps signal?, or do you have any other pointers?
    [edit]
    Centrafuse is not displaying any error messages or statuses that indicates any problems communicating with the gps
    Best regards
    T-Bear
    Has the gps issue been fixed?.. is there an updated version I can use... so I can test the gps features before I buy?
  7. #37
    If your GPS worked in 1.13 then the issue you are having has been fixed...
    I plan to release a version today or early tomorrow...
    david
  8. #38
    Nov 2004
    david
    Aahh.. looking forward to it
  9. #39
    Oct 2004
    ok never gotten this on any version i have tried i dont think but gettin it on a brand new install of 1.14 on a brand new isntall of windows xp as well. but if i keep hitting the eject button next to the hard drive section in media it shoudl go to a nothign playlist and all music and videos stop. but i get all the way down to 0 and there is still a playlist playing!!! how is that possible. that and some times it dosnt save thecurrent playlist that was playing when i exit CF and go back in like it used too. and go right back to the exact song i was playing last time.
  10. #40
    Aug 2004
    On the edge!
    Well I set CF up on house PC and then copy to CarPC and guess what? I can't activate it as its now tagged to my house PC.
    Well its either than or my reinstall of XP after Vista which has casued it.
    Also:
    Using Silabs radio, it works fine till I switch channels then I get the new channel playing twice, sort of repeated, I pressume this is down to the Radio buffer?!?!
    EDIT: This double radio issue stopped when Radio Buffering is turned off
  1. Centrafuse 1.11 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 04-16-2007, 11:28 AM
  2. Centrafuse 1.1 Bugs
    Last Post: 03-13-2007, 09:11 PM
  3. Centrafuse RC5 Bugs
    Last Post: 02-26-2007, 06:00 PM
  4. Centrafuse RC4.3 Bugs
    Last Post: 12-10-2006, 02:48 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
