are you running NMEA mode? Try setting to 9600 baud...
Go to the Centrafuse install folder and open the file Destinator.ini in a text editor... Towards the bottom you will see COM1 or whatever your COM port is set too... Make sure this is saying COM3...
Try changing to COM1 and then back to COM3
note: You most likely need to open the file Destinator.ini in a HEX editor such as Ultraedit though, you can email it to support and I will look at it...
david
LinkBack URL
About LinkBacks
